Does anyone have a code snippet or advice on easily writing results from an InstallScript custom action to the MSI database?
Specifically, I am attempting to list the SQL Servers available in a listbox in a Basic MSI project. I found a great code snippet here on InstallSite that will list the SQLServers, but I need to be able to write the results back to the listbox table in the MSI database.
I'm a relative novice at InstallScript.
Thanks in advance!
John
Writing from InstallScript to MSI Database
MNJon
, Dec 30 2003 17:49
Posted 31 December 2003 - 09:13
In your InstallShield program directory under Samples\ScriptSamples you'll find a .rul file that includes a function to add entries to a combo box. List boxes work quite similar to combo boxes.
Posted 31 December 2003 - 17:53
Thank you! I wasn't aware of the code samples that were installed with InstallShield.
I'm having a little problem getting the sample code to run. I can step through the code with no errors, but nothing seems to get written back to the ComboBox table. Shouldn't I be able to see these entries in the ComboBox table of the MSI file being executed in the temp folder?
I'm not a whiz in InstallScript and am likely missing something basic - any ideas?
Thanks GREATLY in advance for your help!
John Frid
John Frid
Posted 31 December 2003 - 18:44
The SDK states that the database cannot be changed at runtime. You can only add, modify, remove temporary rows, columns or tables from a database. I assume this means that any changes you do will be "in memory" only and never be persisted to disk.
