I have a major upgrade with selections of " completely uninstall old setup before installing new setup" and "include maximum version = yes". This all works fine, except I have noticed that the files of previous versions are not being updated from the target location, even the program gets updated correctly from the Add/Remove Programs list. How to correct this?
Upgrade did not update files on target machine
misun
, Sep 12 2003 19:00
Posted 15 September 2003 - 05:43
Try running your install in verbose log mode and this should tell you why the files are not being updated.
Posted 16 September 2003 - 17:29
The reason files didn't get installed is because three is no vesion number for those files. I use "overide system version" Property to correct the problem.
But in some cases I use "dynamic file linking", I can only set version propety on the key file, not the rest of the files. Is there any other ways? Thanks!
