Hello everyone,
Hopefully someone can help me out there. I'm using IS 5.1 on Windows NT.
My problem is, I have 3 copy of files to do. The first one is in lets say Directory A and uses TARGETDIR. The second copy of files is in Directory B and uses WINDIR\fonts. The third one (which doesnt work) should go in Directory C and uses a script-defined folder.
The script-defined variable is named svDirThirdOne. Now how do I copy files in two different directories at the same time? I call ComponentSetTarget for the Third Directory (setting the value) just before ComponentMoveData but it gives me an error when I execute the InstallShield (when its installing).
It does the 2 other directories fine (TARGETDIR AND WINDIR/FONTS), but not the third one..
Am I doing this the wrong way? I'm missing something here..
All help is appreciated!
Thank you in advance,
Dominic Marcoux
Multi-Directories Installation
Werzoth
, Jul 08 2002 19:33
Posted 09 July 2002 - 18:23
| Quote |
| I call ComponentSetTarget for the Third Directory (setting the value) just before ComponentMoveData but it gives me an error when I execute the InstallShield (when its installing). |
What error message/number do you get?
Does the directory exist that is used for ComponentSetTarget(...)?
Gruß / regards
Thomas
Thomas
Posted 09 July 2002 - 18:28
I get an error -145. (Target path for the component or file group cannot be found.)
Altho. all the directories exists and are typed in correctly.
Posted 09 July 2002 - 18:37
Did you debug and verify the contents of the variable?
Did you use exactly the same names in script and IDE?
I remember having the same problem while I used <szTarget> in the script and <SZTARGET> in component definition in the IDE ...
Maybe this helps ...
Gruß / regards
Thomas
Thomas
