In a standard project with developer 7 .. I am giving the user an option to set up some COM+ files that is packaged in a seperate *.msi file.
I used the Custom Action Wizard to "launch another .msi package" and then executing a Sequence/Action. This works if I want to install COM+.msi everytime, but this is not the case.
I have a feature named COM+ and if a user selects this .. then install .. if not selected .. skip. How and can I use deferred execution? Or something along these lines? Not to execute unless this feature is checked
I tried writing a custom fuction ...
export prototype COM_Installing();
COM_Installing()
begin
end;
... and using LaunchAppAndWait() .. but I get an install instance already running. Even went as far as creating a batch file that calls msiexec.exe with commands to run the com.msi.
I've tried around 5 different ways now .. and caving in to ask .. I assume this is easy and I am missing something.
Thanx for anyones help, -Mayo
scott_mayo99@yahoo.com
