Hi ,
Following is the scenario:
1. My installer stores some data in C:\Documents and Settings\All Users\Application\XYZ directory on XP and in C:\ProgramData\XYZ on Vista.
2. At the time of up-gradation I am getting following error on Vista and windows 7.
Error -1303: The Installer has insufficient privileges to access this directory
C:\ProgramData\XYZ.
3. There is no problem on XP.
4. I have given administrator rights to the setup.exe and the custome action dlls that I am using.
5. Files in the XYZ folder are dynamically linked.
6. The above error occurs at the time of up-gradation only , re installation , new installation and un-installation works fine.
Would you please help me out.
Sumit.
At the time of upgradation getting error 1303 on V
sumit_pyk
, Aug 10 2009 09:34
Posted 10 August 2009 - 11:13
Check the owner and acess rights on the existing files. Process Monitor from SysInternals might also help to diagnose the problem.
