Every time I uninstall my application I get the RebootDialog. At least when I uninstall with my shortcut to DISK1TARGET^Setup.exe. If I go from Add/remove it works fine. Is there any way I can overide the dialog or not make it happen. I'm all out of ideas. Have anyone had a similar problem? What calls for the RebootDialog? I meen I guess it's because it tries to uninstall a locked file or something, though I do not get that message(from OnLockedFile).
Thanks in advance!
Uninstall problem..
jive02
, Aug 09 2002 00:43
Posted 09 August 2002 - 03:49
And your shortcut exactly matches what is being used for Add/Remove Programs? 'cause it doesn't sound at all like it does. Especially if you're pointing to DISK1TARGET^Setup.exe.
Your shortcut should instead be calling what's in
HKLM\Software\Microsoft\Windows\CurrentVersion\<InstallGUID>\UninstallString
