Hi all,
My installation doesn't work on a new rebuilt NT4 SP5 machine with IE5.0. This is a stand alone (not a domain member) server. I can reproduce this on any such machine. This installation works fine on W2K or NT4 domain member. The user log in as administrator.
The MSI log file says:
Action start 11:13:28: SetMessageLogParm.
MSI © (9C:74): Creating MSIHANDLE (1) of type 790542 for thread 116
MSI © (9C:74): Closing MSIHANDLE (1) of type 790542 for thread 116
MSI © (9C:74): Note: 1: 2737 2: SetMessageLogParm 3: C:\TEMP\MSI26D.tmp 4: SetMessageLogParm
Internal Error 2737. SetMessageLogParm, C:\TEMP\MSI26D.tmp, SetMessageLogParm
Action ended 11:13:28: SetMessageLogParm. Return value 1.
where SetMessageLogParm is a routine from my install.dll.
How can I understand why the installation package doesn't have access to my dll on this machine?
Any help would be great appreciated.
Internal error 2737
Irina
, Mar 29 2002 17:39
Posted 29 March 2002 - 17:39
Irina Shirinsky
Software Engineer, Heroix Corporation
http://www.heroix.com
Posted 03 April 2002 - 13:27
2737 can be caused by calling a routine that is not in the dll. This is not the problem in your case.
2737 can also be caused by a reference to a second dll. I recently added code to install a plug and play driver to my setup. I quickly got a complaint from the test department that windows 9X and NT4 installations failed with 2737. I investigated and discovered a new dependenecy on NEWDEV.DLL which should not normally be present in 9X or NT4.
I expect you have a similar problem. Perhaps you can open your dll with Microsofts dependency program. This will tell you which dll is missing on your problem machine.
Ian Blake
(Currently Unemployed)
Posted 03 April 2002 - 21:16
Hi Ian,
Thank you very much for your advice.
I have added to my installation dll some routines to apply the installation on the cluster server and this dll uses now clusapi.dll. This file is missing on my test machine. I put clusapi.dll on the system32 folder and the installation works!
Irina Shirinsky
Posted 04 April 2002 - 15:00
Putting clusapi.dll in sytem32 proves the source of the error but in general I think installing unsed dlls is a bad idea.
It may be better to link to the dll in the old fashioned dynamic way. The code I used was a variation of.
I do not link with newdev.lib or use newdev.h although I did adapt the declaration of UPDATEDRIVER from UpdateDriverForPlugAndPlayDevicesA in newdev.h
| Code Sample |
typedef BOOL (__stdcall * UPDATEDRIVER) ( HWND hwndParent, LPCSTR HardwareId, LPCSTR FullInfPath, DWORD InstallFlags, PBOOL bRebootRequired OPTIONAL ); HMODULE hLib = LoadLibrary("NEWDEV.DLL"); UPDATEDRIVER UpdateDriver = (UPDATEDRIVER)GetProcAddress(hLib, "UpdateDriverForPlugAndPlayDevicesA"); UpdateDriver(NULL, HardwareId, InfPath, 0, &bReboot); FreeLibrary(hLib); |
Ian Blake
