I use ISWI 1.52.
I have released a product in english.
I now have to ditribute it in Japonese. I have translated my string table in Japonese and rebuild.
During the installation, I sometimes display MessageBox, but the MessageBox does not seem to be able to display Japonese text.
Is it possible to change the default font used by MessageBox?
Thanks for your help.
Message not correct in Japonese
jsp
, Sep 24 2001 09:37
Posted 24 September 2001 - 16:13
What looks like a MessageBox in most cases is the ErrorDialog that is included in your project.
Posted 28 September 2001 - 14:11
I think you are talking about SetupError dialog: It works properly with the good font.
But the MessageBox that has problems is launched by my script via a Custom Action.
I am not able today to solve that problem.
Any idea?
Any idea?
Posted 28 September 2001 - 16:28
Yes, I meant SetupError.
I assume that the MessageBox Windows API will use the operating system font. You may need to install Japanese language support, and maybe also adjust the system and user locale.
Posted 28 September 2001 - 16:31
I have already installed the East langage pack from InstallSield, but it wasn't enought.
I rebuild my setup on a Japonese Operating System: it works.
Posted 19 June 2002 - 10:32
Hi
I have the same problem using MessageBox'es, AskYesNo() etc. in Japaneese, Korean & Chineese -
I'm using the InstallShield Windows Installer 2.03.
Is the only solution to setup 3 different build computers!??!?
Have anyone found a better solution
Thanking You in anticipation
Regards,
Thomas Eskesen
Regards,
Thomas Eskesen
