I have a problem where the modify/Repair or an upgrade fails if the modify/repair is not done by the user who has originally installed the software.
I always get the prompt for asking to select the source CD even though the user who is trying to upgrade is an administrator. Unless I use the user account who originally installed the software I am not able to proceed.
Is this an intended functionality or is it a bug?
I am using INstallscript based Msi project and it is on Installshield 10.5 version.
Any help or pointers in this will be really helpful.
Vishal
upgrade fails if user is not the original user
vishalv
, Feb 13 2007 06:18
Posted 13 February 2007 - 09:03
Repair always requires access to the source media. Maybe it was copied to the local hard disk in a folder that the administrator can't access (the user's profile) or only under a different path or name, or you installed from a mapped network drive letter which is not mapped for the administrator.
Posted 13 February 2007 - 12:23
Hi Stefan,
Thanks for the reply.
When we encountered this problem we mapped to the network drive which was used by the original user account to install the software.
Also the user was an administrator and the folder where the msi is cached for later use should be available to the user as it was a per machine installation.
Could we ask the end user to make sure that he upgrades the software using the user account which was used to install the software?
Thanks once again,
Vishal
Thanks once again,
Vishal
