Is it possible to have a dialog before SplashBitmap dialog? Actually the new dialog should become the entry point of the installer rather than the default SplashBitmap or InstallShiled Wizard Dialog... and then the flow can follow the regular sequence.
Any ideas or suggestions ?
Presenting Dialog before SplashBitmap Dialog
Neomatrics
, Apr 23 2004 06:20
Posted 23 April 2004 - 15:20
You can insert a dialog before the splash screen that is in your msi. But if you launch your setup via setup.exe you may see another dialog while InstallShield installs the msi runtime. If you want a dialog before that you would have to do this using an external exe.
