I have MSI with Shortuct. In installation dialog I have checkbox for shortcut. When I Install application and check/uncheck checkbox the shortcut is install/not install. It is correct. Wrong behaviour appers when:
First I install application and checkbox is unchecked, so shortcut not will be installed.
Second I run Modify Installation and checbox is checked, but after modify process the shortcut still not be present.
Technical details:
Property Table"
"SHORTUCT1","1"
Component Table:
"DesktopFolder","{1F4A38F8-576D-4201-819C-4577DCFBF71D}","DesktopFolder","4","SHORTUCT1 = 1","registry","Windows\Profiles\Desktop"
FeatureComponents
"Complete","DesktopFolder"
Registry Table
"registry","1","Software\XXX\Test","DesktopFolder","[INSTALLDIR]\TDM.exe","DesktopFolder"
I don't have Idea what is wrong. :-(
Thank you for your help
