Hi All,
I need urgent help!!!
The development is done on Developer 8.0.
I make major upgrade from version 1.0 to 2.0 because msi name was changed.
The following changes were done:
I changed ProductCode value and remained same UpgradeCode value ({224B7F85-267A-4C7A-A19D-1E88263AC126})
Two upgrade items were added with the same UpgradeCode and Upgrade table was populated.
1. VersionMin = NULL, VersionMax = 1.0, Attributes=513, ActionProperty = OLDPRODUCTS
2. VersionMin = 2.0, VersionMax = NULL, Attributes=2, ActionProperty = NEWERPRODUCTS
SecureCustomProperties = OLDPRODUCTS;NEWPRODUCTS
While I’m running new version of product (that includes upgrade) after version 1.0 is installed, from logger we can that someway the old version from cache is running and therefore any type of upgrade can’t work.
Here is fragment from logger.
******* Product: G:\DevW2k\PolicyServer\install\Windows\eTrust WAC Policy Server\Windows\Release\DiskImages\Disk1\eTrust Web Access Control - Policy Server.msi
******* Action:
* CommandLine: **********
MSI © (A8:28): Machine policy value 'DisableUserInstalls' is 0
MSI © (A8:28): Cloaking enabled.
MSI © (A8:28): End dialog not enabled
MSI © (A8:28): Original package ==> G:\DevW2k\PolicyServer\install\Windows\eTrust WAC Policy Server\Windows\Release\DiskImages\Disk1\eTrust Web Access Control - Policy Server.msi
MSI © (A8:28): Package we're running from ==> G:\WINNT\Installer\58c8e4.msi
MSI © (A8:28): APPCOMPAT: looking for appcompat database entry with ProductCode '{224B7F85-267A-4C7A-A19D-1E88263AC126}'.
MSI © (A8:28): APPCOMPAT: no matching ProductCode found in database.
MSI © (A8:28): Transforms are not secure.
MSI © (A8:28): Command Line: SETUPEXEDIR=G:\DevW2k\PolicyServer\install\Windows\eTrust WAC Policy Server\Windows\Release\DiskImages\Disk1 CURRENTDIRECTORY=G:\DevW2k\PolicyServer\install\Windows\eTrust WAC Policy Server\Windows\Release\DiskImages\Disk1 C
LIENTUILEVEL=0 CLIENTPROCESSID=2216 %HOMEPATH=\ %HOMEDRIVE=G: %HOMESHARE=
MSI © (A8:28): Product Code passed to Engine.Initialize: '{224B7F85-267A-4C7A-A19D-1E88263AC126}'
MSI © (A8:28): Product Code from property table before transforms: '{224B7F85-267A-4C7A-A19D-1E88263AC126}'
MSI © (A8:28): Product Code from property table after transforms: '{224B7F85-267A-4C7A-A19D-1E88263AC126}'
MSI © (A8:28): Product registered: entering maintenance mode
MSI © (A8:28): Entering CMsiConfigurationManager::SetLastUsedSource.
MSI © (A8:28): Specifed source is already in a list.
MSI © (A8:28): User policy value 'SearchOrder' is 'nmu'
MSI © (A8:28): Machine policy value 'DisableBrowse' is 0
MSI © (A8:28): Machine policy value 'AllowLockdownBrowse' is 0
MSI © (A8:28): Adding new sources is allowed.
MSI © (A8:28): Package name retrieved from configuration data: 'eTrust Web Access Control - Policy Server.msi'
MSI © (A8:28): Determined that existing product (either this product or the product being upgraded with a patch) is installed per-machine.
MSI © (A8:28): Note: 1: 2729
MSI © (A8:28): Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI © (A8:28): Machine policy value 'DisableMsi' is 0
MSI © (A8:28): Machine policy value 'AlwaysInstallElevated' is 0
MSI © (A8:28): User policy value 'AlwaysInstallElevated' is 0
MSI © (A8:28): Product {224B7F85-267A-4C7A-A19D-1E88263AC126} is admin assigned: LocalSystem owns the publish key.
MSI © (A8:28): Product {224B7F85-267A-4C7A-A19D-1E88263AC126} is managed.
MSI © (A8:28): Running product '{224B7F85-267A-4C7A-A19D-1E88263AC126}' with elevated privileges: Product is assigned.
[U]
major upgrade doesn't work
gelya
, Mar 10 2003 19:01
