Hi .. i want to call the function of a spcefied dll, i have used UseDll function but dll failed to load by this function. than i used Calldllfx but I think it is also not able to call the function. Is there any other function by which I can call the function.
regards
calling a .dll function in install sheild
amit08
, Jun 16 2008 15:04
Posted 17 June 2008 - 16:28
You may need to fix the function type in the DLL or adjust the calling convention. If the call to useDLL fails howevcer I guess that the DLL has a dependency that is missing. DependencyWalker should tell you.
