What is the easiest way to tell Windows Installer to run a program after a Scheduled Reboot? Because of profiles I'm trying to stay away from a shortcut in the Startup folder
Run a program after reboot
FPSStephen
, Nov 08 2001 18:39
6 replies to this topic
Posted 08 November 2001 - 20:03
In which key do I write to runonce? Do I write the program name there?
Posted 11 November 2001 - 12:34
Hi ,
In HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\RunOnce
Create new string value and set your application path in data of this value.
Posted 12 November 2001 - 17:48
Is there a way to write this registry key only when the user has selected to install a certain feature or component?
Posted 14 November 2001 - 17:55
Yes of course it is possible to conditionnaly install this registry key: use MsiGetFeatureState function in your script.
Hope it helps.
Regards,
JSP
Hope it helps.
Regards,
JSP
Posted 14 November 2001 - 21:14
Given that a registry key is related to a particular component then the registry key will only ever be installed if the related component is installed
