If anyone could take a look at the following custom action, I would appreciate the feedback. This custom action is triggered from a DoAction event on a dialog next button. The custom action fails and the install immediately goes to the finish dialog. It's a type 6 custom action. As usual, the code works outside Windows Installer and I am wondering if there are restrictions on using the RegExp object in Windows Installer. Thanks in advance for the help.
Problem with a VBScript custom action
ajshurts
, Mar 30 2007 00:20
6 replies to this topic
Posted 30 March 2007 - 00:20
| Sub VerifyInfo() dim strSerial, strHost, strPattern dim objRegExp strSerial = Session.Property("SERIAL") strHost = Session.Property("HOST") Set objRegExp = New RegExp strPattern = "[a-fA-F0-9]{8}\-[a-fA-F0-9]{8}" objRegExp.Pattern = strPattern If(objRegExp.Test(strSerial)) Then Session.Property("SERIAL_VALID")=1 Else Session.Property("SERIAL_VALID")=0 End If strPattern = "^(http)s?(\:\/\/)([a-zA-Z0-9\.\-]+)((\/)?)$" objRegExp.Pattern = strPattern If(objRegExp.Test(strHost)) Then Session.Property("URL_VALID")=1 Else Session.Property("URL_VALID")=0 End If End Sub |
Posted 30 March 2007 - 16:47
Some extra info...
It is crashing when executing the Test method. It is however able to create the RegExp object and set the Pattern property. I also tried the Execute method, but it crashed as well. If this helps, I am on script version 5.7 and Windows Installer 3.1.
Posted 31 March 2007 - 17:55
The RegExp object was introduced in Active Scripting 5.0, which comes with a number of products, IE 5.0 is one of them.
What you can do is start with "On Error Resume Next", causing the script to continue despite any errors occuring.
To find out more information about the errors that did occur, write after each suspicious statement:
if Err.Number <> 0
MsgBox Err.Description
Err.Clear
endif
Also consider writing "Option Explicit" at the top of the script (before the Sub), this forces the script to generate an error when a variable is introduced that was not DIMmed (usually means a typing error).
Hope this helps you debug your scripts.
if Err.Number <> 0
Err.Clear
endif
Posted 02 April 2007 - 04:48
I am not sure, but I think MSI hosts is own VBScript runtime that is run in quiet mode. I am hence not sure if message boxes will show up. If you don't see any boxes, try writing Err.Description to a log file instead. Again, not positive if message boxes are suppressed, but just in case...
Posted 02 April 2007 - 12:03
The solution is simple. Session.Property need a string but you set a integer value. The following code works perfectly:
Sub VerifyInfo()
dim objRegExp
Session.Property("SERIAL_VALID")="1"
Else
Session.Property("SERIAL_VALID")="0"
End If
Session.Property("URL_VALID")="1"
Else
Session.Property("URL_VALID")="0"
End If
End Sub
Additionally: Your CA is unsecure, because the script logic is readable by everyone. It is better to use DLL for such implementation.
Sub VerifyInfo()
dim objRegExp
Else
End If
Else
End If
End Sub
Andreas Kerl
Inside Windows Installer 4.5
ISBN 3-86645-431-7
Posted 03 April 2007 - 03:10
I agree on the security issue, however it would probably be even better to do the serial code validation in the application.
Posted 09 April 2007 - 21:28
| QUOTE (akerl @ 2007-04-02 12:03) |
| The solution is simple. Session.Property need a string but you set a integer value. The following code works perfectly: Sub VerifyInfo() dim strSerial, strHost, strPattern dim objRegExp strSerial = Session.Property("SERIAL") strHost = Session.Property("HOST") Set objRegExp = New RegExp strPattern = "[a-fA-F0-9]{8}\-[a-fA-F0-9]{8}" objRegExp.Pattern = strPattern If(objRegExp.Test(strSerial)) Then Session.Property("SERIAL_VALID")="1" Else Session.Property("SERIAL_VALID")="0" End If strPattern = "^(http)s?(\:\/\/)([a-zA-Z0-9\.\-]+)((\/)?)$" objRegExp.Pattern = strPattern If(objRegExp.Test(strHost)) Then Session.Property("URL_VALID")="1" Else Session.Property("URL_VALID")="0" End If End Sub Additionally: Your CA is unsecure, because the script logic is readable by everyone. It is better to use DLL for such implementation. |
Thank you!! I can't believe I overlooked that. This isn't the actual serial number validation. We have a DLL that does that in the application. However, I want to make sure what they enter is in a valid format. Thanks a ton for the help.
