I am a beginner to Installshield 2009...
I use "General Information->Product Properties->Install Condition" to check minimum requirement for the installation...
I can check the Memory by "PhysicalMemory>512"...
But how to check CPU, IE version, Harddisk free spcace, font and OS Language..??
Also, i don't the syntax to write condition statement ... the "InstallShield Help" only show a few example. Where i can find more information about that?
Thx very much!!
Check CPU, Memory, IE version.etc...
jessiechow
, Feb 11 2009 05:44
Posted 11 February 2009 - 15:06
In Install Conditions you can use many pre-defined properties, or set your own properties using System search.
For a list of predefined properties see help topic "Property Reference".
For IE there's a pre-buit condition (based on a system search). To use it switch to the Project Assistant view and go to the Installation Requirements panel.
Posted 12 February 2009 - 04:31
Thank very much...
while i need to check IE version 5.5, the Installation Requirements panel only check IE version 5,6 or 7... so i change to use the "Prerequiste Editor" to check the register "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer"...
For the Font, i use a "Component Wizard" to do...
I am now trying to use System Search for the other property..Thx very much
