I'm new to Installshield DevStudio 9, previously used Orca to author packages.
Is it possible to add an existing MSM into a MSM. For example, authoring a common components MSM which needs MSXML 4.0 MSM. I can't find any way of doing this using DevStudio 9.
WD.
Adding a merge module to a merge module
willyd
, Aug 18 2004 18:52
Posted 18 August 2004 - 23:48
This doesn't really make sense. Merge modules are atomic units of files / registry entries to be shared among several products. You include merge modules in MSI's not in other merge modules.
Posted 19 August 2004 - 10:51
What you could do is to specify the Module Dependencies. That can be achieved by using the General Information view in the Merge Module project.
Posted 19 August 2004 - 10:58
You can't add a merge module to another megre module, i.e. merge modules can't consume merge modules.
You can however add the other merge module to the ModuleDependencies table.
