Hey,
Ive got a bit of a tricky problem, I need to remove a Windows Installer installed application but without using the Windows Installer itself. I have had a look at MSIZap.exe and miscuu.exe but I would like to write my own utility that will remove an application.
Has anyone attempted this before? Would you be able to give me a listing of all the reg entries pertaining to a windows installer based install?
Any help would be greatly appreciated.
Pete.
Removing Windows Installer based apps
reflex
, Jul 02 2003 14:08
Posted 02 July 2003 - 23:33
| Ive got a bit of a tricky problem, I need to remove a Windows Installer installed application but without using the Windows Installer itself. |
Your've mentioned the solution, what is the problem?
Sounds like what you want to do is some last ditch desperate act after all else has failed?
I assume you are having frequent problems making it impossible to uninstall these, fixing this might be a better idea....
My 2 cents woth,
Dennis
Dennis Bareis (dbareis@No.Spam.gmail.com)
Free MSI update/creation tool (MAKEMSI):
http://users.cyberon...eis/makemsi.htm
Posted 03 July 2003 - 09:47
The problem is occurring when we try and upgrade from previous versions of our software, the upgrade doesnt remove the app correctly or the upgrade just plain fails.
What I would like to do is run an exe or another type of utility that would force the removal of the previous version (without using the Windows Installer service).
I hope this makes the situation a little more clearer.
Pete.
Pete.
Posted 03 July 2003 - 09:50
Using Windows Installer to uninstall the existing version is the recommended method. Why do you need to avoid this?
