My installation is on two discs and during the install I'm asked to change CD's something like eight times. It seem like there's parts of files in different cab's. I've made a custom size media sized 600 megs cuz I have to fit in some other stuff on each CD. Has anyone had a similar problem and found a solution?
Annoying problem
jive02
, Apr 04 2002 11:15
Posted 04 April 2002 - 18:49
Never done more than one CD for an install, but sounds like you need to play with how the CAB files are layed out in your media setup. Obviously the default isn't the way to go with your setup.
Posted 14 April 2002 - 16:17
I can't really find any settings to play with. I have a clue what might cause the problem though. It seems like the files that are in file-groups that are language-depentent is the source of evil. I still link them to the same component. Does this sound like something one shouldn't do?
Also, when the installation is completed, and the second disc is in my drive, Setup alerts me and says that the wrong CD is in the drive. If I change CD all is good, but if i press cancel, the setup app crashes. I've accually seen this on other installations (some of the most popular games of today) so I guess this is a common problem. Does anyone know a way to avoid this?
- jonas
