How to config IIS virtuall directories ..
I want to set a IIS virtual directories and ftp virtual directories on installing
and Uninstall all that virtual directories on unistalling....
How can I do?
Please Help me....
How to config IIS virtual directories
reback
, Dec 29 2003 15:03
Posted 08 January 2004 - 21:19
There is a good sample C++ project on this site that will add/delete virtual directories, as well as add/delete ifilters.
My problem is getting this project to compile in VS Studio 2003. I keep getting the following error messages:
1. activeds.tlh(523): error C2011: '_LARGE_INTEGER' : 'union' type redefinition
2. AsyncInstall.cpp(1068): error C2664: 'ADsGetObject' : cannot convert parameter 1 from 'const char [29]' to 'LPCWSTR'
Does anyone know how to fix this?
Posted 09 January 2004 - 10:59
Another option would be the IIS configuration view in DevStudio. However that's only available in MSI projects, not in InstallScript projects.
Posted 04 February 2004 - 12:40
It's quite easy to access IIS from installscript. using ADSI.
Below are some basic functions for creating and deleting a virtual directory.
The code is not tested, but I think it is more or less correct.
For more information about ADSI look at Microsoft's website.
/Max
Add virtual directory:
/Max
function CreateVirtDir(sVirtDir, sVirtDirPath) OBJECT oIISRoot; OBJECT oIISDir; begin try set oIISRoot = CoGetObject("IIS://LocalHost/W3SVC/1/ROOT",""); if IsObject(oIISRoot) then set oIISDir = oIISRoot.Create("IIsWebVirtualDir", sVirtDir); oIISDir.Put("Path",sVirtDirPath); oIISDir.Put("AccessRead","true"); oIISDir.Put("AccessWrite", "false"); oIISDir.Put("EnableDirBrowsing", "false"); oIISDir.Put("AppFriendlyName",sVirtDir); oIISDir.SetInfo(); endif; catch endcatch; end; |
Delete Virtual directory:
function DeleteVirtDir(sVirtDir) OBJECT oIISRoot; begin try set oIISRoot = CoGetObject("IIS://LocalHost/W3SVC/1/ROOT",""); if IsObject(oIISRoot) then oIISRoot.Delete("IIsWebVirtualDir",sVirtDir); endif; catch endcatch; end; |
Edited by mabr, 04 February 2004 - 12:48.
