Hi all,
I'm having a bit of a problem.
I have a Suite Project with a few packages that are installed. One in particular adds some registry keys and values when installed, and deletes them when uninstalled (which is necessary).
The package works fine when used alone, but when I incorporate it into the Suite Project, it does not uninstall.
At first, I wanted this specific package not to show up on ARP, so I removed the PublishProduct CustomAction from the package. I then build the project and inserted the package inside the Suite Project, and it wasn't uninstalling at all.
I figured the CA was probably needed or something, so I re-inserted it at it's rightful place, but ever since I did that, the package shows up in ARP but there are no options whatsoever....oh, and it still doesn't uninstall!
Did I do something terribly wrong, or is there something I'm missing ?
Thanks!
