I have a Setup.iss file that I wish to modify, so that installation path is NOT hard coded. Currently, it always uses C:\Program Files\..., but I'd like it to be X:\Program Files where X: is the current Program Files location.
Here's the corresponding section of ISS code:
[{02E7DB6A-B120-11D4-A3F4-00C04F606097}-SdAskDestPath-0]
szDir=C:\Program Files\Canary Labs
Result=1
Now, I've tried just dropping the szDir line, but then I got -3 result (Required data not found in the Setup.iss file). I know from previous experience that if I drop the whole section, I'll get the same error. So rather than try a bunch of different combinations, I wondered if you guys might have any ideas.
I do know that one solution would be for me to manually re-write that line during install time, but I'd prefer another way if at all possible.
Customizing Silent Installations
Taco Bell
, Mar 28 2002 17:11
Posted 03 April 2002 - 09:00
That's an interesting question; have you found an answer yet?
You perhaps won't be able to change the iis-file at runtime cause it's being accessed!?
Posted 03 April 2002 - 15:02
No answers yet ... still waiting to see if anyone has some ideas.
No the file won't be in use because this is a third party app. which we apply during our setup, so it's not accessed until I make the call to silently run the setup. I have plenty of time beforehand to modify it on-the-fly, which more and more seems like what I'll end up having to do.
Posted 27 April 2002 - 03:44
**bangs head on desk**
I should have thought of this earlier, but an idea I recently had is to just use the following system macro:
%ProgramFiles%
I'll give this a whirl and let you all know if it works out.
%ProgramFiles%
