Set Component property 'Permanent' default 'True'
dbarnwal_123
, Feb 15 2008 09:40
Posted 15 February 2008 - 09:40
Hi, I am working on Installshield 12. I am making an MSI package for a release.
There are different components under Organization -> Components.
There is a property called Permanent which is set as False.Currently I have to select each of the component one by one and set it as 'True' manually.
Is there any setting/configuration for which we can set this as True for
all component default.
I will be waiting for your responses.
DB
Posted 15 February 2008 - 14:50
QUOTE |
I am making an MSI package for a release. |
QUOTE |
THIS SECTION IS NOT FOR MSI (WINDOWS INSTALLER) PROJECTS, not even for "InstallScript MSI" |
I'll move your questionto the MSI part of the forum.
Posted 15 February 2008 - 14:52
There's no built in facility to do this, but you could probably write some script for this purpose.
But are you really sure you never want to uninstall any of your components?
