I use Macrovision's Adminstudio InstallShield to create packages that we push via AD GPO (no SMS here). By default our wkstn's grant only Read&Execute to newly created folders in root C (done via GPO). Within an MSI I want to create a new root folder and grant %COMPUTERNAME%\Users "modify". In the "Permissions" window of a newly created folder in IS Editor what do I put in the "Domain" field to specify the local computer name? (I tried %COMPUTERNAME% but no luck). Or can I even?
Granting "modify" to mydomain\Domain Users would be an acceptable solution, but when I do this it doesn't work, specifically, it recognizes the AD group and puts it in the ACL of the folder but members of Domain Users get no such rights in reality.
-CouverKyle
NTFS granting to Local groups within MSI
CouverKyle
, Sep 13 2005 18:12
Posted 15 September 2005 - 20:17
Try [%COMPUTERNAME]
I'm not sure it will work, but the variables need to have square brackets and a % sign. The example in the help file was for a domain and they used
[%USERDOMAIN] for the variable.
I don't know why they won't let you use regular variable names, but I've never been able to get them to work without the brackets and only one % sign.
You could also leave the domain part blank and just put in LogonUser in the user field. That would grant permissions to the currently logged on user.
