I want my installer to detect whether it has already been previously installed and if so display my own custom msg instead of showing the default Windows Installer error:
Another version of this product is already install
integer
, Mar 06 2013 18:42
Posted 06 March 2013 - 18:42
| Another version of this product is already installed. Installation of this version cannot continue. To configure or remove the existing version of this product, use Add/Remove Programs on the Control Panel. |
I have 32-bit and 64-bit versions of my installer for the same product which have (nearly) the exact same code & custom action sequence (there are only minor differences which are not relevant to this issue)
My 32-bit installer works perfectly fine (it shows my custom msg if I run the installer when the product is already installed), but my 64-bit installer does NOT work correctly and always shows the unwanted Windows error msg.
CheckPreviousVersion is the first function called as a Custom Action during the UI sequence, I've tried putting it in different spots (after InstallValidate) but nothing works. I've generated a verbose log file but I can't tell if there's anything useful in it that might explain this behavior:
=== Verbose logging started: 05/03/2013 16:27:20 Build type: SHIP UNICODE 5.00.7601.00 Calling process: C:\Windows\system32\msiexec.exe === MSI © (0C:70) [16:27:20:258]: Font created. Charset: Req=0, Ret=0, Font: Req=MS Shell Dlg, Ret=MS Shell Dlg MSI © (0C:70) [16:27:20:258]: Font created. Charset: Req=0, Ret=0, Font: Req=MS Shell Dlg, Ret=MS Shell Dlg MSI © (0C:94) [16:27:20:331]: Resetting cached policy values MSI © (0C:94) [16:27:20:331]: Machine policy value 'Debug' is 0 MSI © (0C:94) [16:27:20:331]: ******* RunEngine: ******* Product: Hello World (64-bit).msi ******* Action: ******* CommandLine: ********** MSI © (0C:94) [16:27:21:546]: Machine policy value 'DisableUserInstalls' is 0 MSI © (0C:94) [16:27:21:557]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\single-exec\Hello World (64-bit).msi' against software restriction policy MSI © (0C:94) [16:27:21:557]: Note: 1: 2262 2: DigitalSignature 3: -2147287038 MSI © (0C:94) [16:27:21:557]: SOFTWARE RESTRICTION POLICY: C:\single-exec\Hello World (64-bit).msi is not digitally signed MSI © (0C:94) [16:27:21:558]: SOFTWARE RESTRICTION POLICY: C:\single-exec\Hello World (64-bit).msi is permitted to run at the 'unrestricted' authorization level. MSI © (0C:94) [16:27:21:584]: Cloaking enabled. MSI © (0C:94) [16:27:21:584]: Attempting to enable all disabled privileges before calling Install on Server MSI © (0C:94) [16:27:21:586]: End dialog not enabled MSI © (0C:94) [16:27:21:586]: Original package ==> C:\single-exec\Hello World (64-bit).msi MSI © (0C:94) [16:27:21:586]: Package we're running from ==> C:\single-exec\Hello World (64-bit).msi MSI © (0C:94) [16:27:21:589]: APPCOMPAT: Uninstall Flags override found. MSI © (0C:94) [16:27:21:589]: APPCOMPAT: Uninstall VersionNT override found. MSI © (0C:94) [16:27:21:589]: APPCOMPAT: Uninstall ServicePackLevel override found. MSI © (0C:94) [16:27:21:589]: APPCOMPAT: looking for appcompat database entry with ProductCode '{B8CBA92E-2140-48AB-B4EA-A4C3FF10295B}'. MSI © (0C:94) [16:27:21:589]: APPCOMPAT: no matching ProductCode found in database. MSI © (0C:94) [16:27:21:599]: MSCOREE not loaded loading copy from system32 MSI © (0C:94) [16:27:21:608]: Machine policy value 'DisablePatch' is 0 MSI © (0C:94) [16:27:21:608]: Machine policy value 'AllowLockdownPatch' is 0 MSI © (0C:94) [16:27:21:608]: Machine policy value 'DisableLUAPatching' is 0 MSI © (0C:94) [16:27:21:608]: Machine policy value 'DisableFlyWeightPatching' is 0 MSI © (0C:94) [16:27:21:609]: APPCOMPAT: looking for appcompat database entry with ProductCode '{B8CBA92E-2140-48AB-B4EA-A4C3FF10295B}'. MSI © (0C:94) [16:27:21:609]: APPCOMPAT: no matching ProductCode found in database. MSI © (0C:94) [16:27:21:609]: Transforms are not secure. MSI © (0C:94) [16:27:21:609]: PROPERTY CHANGE: Adding MsiLogFileLocation property. Its value is 'C:\single-exec\INSTALL64.LOG'. MSI © (0C:94) [16:27:21:609]: Command Line: CURRENTDIRECTORY=C:\single-exec CLIENTUILEVEL=0 CLIENTPROCESSID=7948 MSI © (0C:94) [16:27:21:609]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{47A766F9-85F8-4166-80D4-BA91B7415A3F}'. MSI © (0C:94) [16:27:21:609]: Product Code passed to Engine.Initialize: '' MSI © (0C:94) [16:27:21:609]: Product Code from property table before transforms: '{B8CBA92E-2140-48AB-B4EA-A4C3FF10295B}' MSI © (0C:94) [16:27:21:609]: Product Code from property table after transforms: '{B8CBA92E-2140-48AB-B4EA-A4C3FF10295B}' MSI © (0C:94) [16:27:21:609]: Product registered: entering maintenance mode MSI © (0C:94) [16:27:21:609]: Determined that existing product (either this product or the product being upgraded with a patch) is installed per-machine. MSI © (0C:94) [16:27:21:609]: PROPERTY CHANGE: Adding ProductState property. Its value is '5'. MSI © (0C:94) [16:27:21:609]: PROPERTY CHANGE: Adding ProductToBeRegistered property. Its value is '1'. MSI © (0C:94) [16:27:21:609]: Entering CMsiConfigurationManager::SetLastUsedSource. MSI © (0C:94) [16:27:21:609]: Specifed source is already in a list. MSI © (0C:94) [16:27:21:609]: User policy value 'SearchOrder' is 'nmu' MSI © (0C:94) [16:27:21:609]: Machine policy value 'DisableBrowse' is 0 MSI © (0C:94) [16:27:21:609]: Machine policy value 'AllowLockdownBrowse' is 0 MSI © (0C:94) [16:27:21:609]: Adding new sources is allowed. MSI © (0C:94) [16:27:21:609]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'. Another version of this product is already installed. Installation of this version cannot continue. To configure or remove the existing version of this product, use Add/Remove Programs on the Control Panel. {B8CBA92E-2140-48AB-B4EA-A4C3FF10295B} MSI © (0C:94) [16:27:21:610]: Note: 1: 1729 MSI © (0C:94) [16:27:21:610]: Product: Hello World (64-bit) -- Configuration failed. MSI © (0C:94) [16:27:21:611]: Windows Installer reconfigured the product. Product Name: Hello World (64-bit). Product Version: 8.7. Product Language: 1033. Manufacturer: Hello World. Reconfiguration success or error status: 1638. MSI © (0C:94) [16:27:21:613]: MainEngineThread is returning 1638 === Verbose logging stopped: 05/03/2013 16:27:21 === |
Posted 07 March 2013 - 11:18
Windows Installer checks if a product is installed before running any of the sequences. If a product is installed then the command line should state an uninstall or update or repair.
Otherwise the installation is terminated with the message you saw.
In this case it detected that the product is installed for the current user (in the log file - ProductState=5)
and the installation was terminated
Usually a wrapper setup.exe checks if the product is installed before starting Windows Installer. It then runs in installation mode if the product isn't already installed, or in maintenance mode if the product is installed.
The behavior you describe for x64 is normal for the situation
The behavior for x32 isn't what I'd expect for the situation. Are you using a wrapper there?
Nir Bar - Application packaging expert
nir.bar@panel-sw.co.il
