I am new to installshield.I have an installscript MSI project.
I have used Enable (STATUSEX) in Installscript to call "SetupProgress" Dialog because "SetupProgress" Dialog is not available under "Installer Designer\User Interface\Dialogs".
I have used banner image for dialogs because of that first label of Dialog displayed over banner image. Now i want to change the position of first label i.e. "Setup Status" label of "SetupProgress" Dialog but i am unable to change Left, Top properties of "Setup Status" label.
Can anyone suggest how I can set Left, Top properties of "Setup Status" label of "SetupProgress"" Dialog .
neha1989
How to set Left,Top properties of Dialogbox item
neha1989
, Jan 16 2013 15:41
Posted 16 January 2013 - 16:08
Is your banner image larger than the standard image? In this case I'd recommend you use the default size.
Are you using a dialog skin?
Posted 17 January 2013 - 06:37
Hi Stefan,
Thanks for your prompt reply.
My banner image size is 499x58.
I have not used dialog skin.
neha1989
neha1989
Posted 23 January 2013 - 19:51
Could you post a screenshot (or e-mail it to skrueger (at) installsite.org )?
