On some Win2k Machines, the following happens.
My Install seems to run fine.
Looking at the Registry, HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Fonts ONLY SHOWS the Arial Black Font!!! Refresh does nothing!!!
Looking at C:\WINNT\Fonts,
ONLY SHOWS the Arial Black Font!!! Refresh makes all pre-existing fonts Reappear!!!
Now Refresh registry and all fonts appear again!
I don't know what's going on. MSDN is no help.
The worst symptom is that if the user runs the uninstall without this quirky refresh process. The uninstall properly uninstalls the font. If the user now shuts down (having uninstalled every font seemingly on their machine (the one arial black)) they will not be able to restart their machine.
Mike Worn
Here are the snippets of code that pertain to the problem:
////////////////////// string defines ////////////////////////////
#define HWND_BROADCAST 0xFFFF
#define WM_FONTCHANGE 0x001D
// your script function prototypes
prototype InstallArialBlackFont();
prototype INT GDI32.AddFontResourceA(STRING);
// your global variables
BOOL bMakeFontAvailable;
NUMBER nFontResult;
STRING sFontFileTTF;
// MAIN PROGRAM
program
bMakeFontAvailable = FALSE;
function ProcessBeforeDataMove()
// TO DO : any other tasks you want to perform before file transfer
function ProcessAfterDataMove()
//Activate Ariblk.ttf font
// Add it to the current system so won't have to restart Windows.
if(bMakeFontAvailable) then
nFontResult = AddFontResourceA(sFontFileTTF);
SendMessage(HWND_BROADCAST,WM_FONTCHANGE,0,0);
if (nFontResult = 0) then
MessageBox("Failed to make the Arial Black font available immediately." +
" To use this font you must restart your system after the " +
"installation is finished.", WARNING);
endif;
endif;
function SetupRegistry()
// Register the Arial Black font
if (bIsWindowsNT) then
nResult = CreateRegistrySet ( "Font_ARIBLK_NT" );
else
nResult = CreateRegistrySet ( "Font_ARIBLK_9X" );
endif;
// Note: The registry files contain the following, respectively:
// [Font_ARIBLK_NT:HKLM:SOFTWARE\Microsoft\Windows NT\CurrentVersion\Fonts]
// Arial Black (TrueType)=S,ARIBLK.TTF
// [Font_ARIBLK_9X:HKLM:SOFTWARE\Microsoft\Windows\CurrentVersion\Fonts]
// Function: InstallArialBlackFont
// Purpose: This function will install the Ariblk.ttf font if it does not
// exist."
function InstallArialBlackFont()
STRING sKey, svResult, sFontDir, sFont;
STRING sSrcDir, svValue;
NUMBER nResult, nvSize, nvType;
begin
// Inititialize stuff.
sFontFileTTF = "ARIBLK.TTF";
// Set font registry location.
sKey = "SOFTWARE\\Microsoft\\Windows NT\\CurrentVersion\\Fonts";
else // bWin95
sKey = "SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Fonts";
endif;
// Set font target directory.
// bWin95 and bWinNT40
sFontDir = WINDIR ^ "FONTS";
// See if the font file already exists.
if (FindFile(sFontDir, sFontFileTTF, svResult) < 0) then
// We DON'T have a Ariblk.TTF file.
// Copy the file.
nResult = ComponentSelectItem(MEDIA, "Fonts", TRUE);
bMakeFontAvailable = TRUE;
else
RegDBSetDefaultRoot ( HKEY_LOCAL_MACHINE );
// We DO have a Ariblk.TTF file. Make sure it has a registry entry.
if (RegDBGetKeyValueEx(sKey, "Arial Black (TrueType)", nvType, svValue, nvSize) < 0) then
endif;
RegDBSetDefaultRoot ( HKEY_CLASSES_ROOT );
endif;
end;
