I am using INSTALLSCRIPT MSI project
I am trying to launch LaunchAppAndWait function in PatchUIAfter. All the paramters and exe works perfectly fine in OnBegin or between any dialog.
If i put the same code in PatchUIAfter InstallScript wont launch the exe(Basically LaunchAppandWait fails).
I checked all the parameters and exe is perfect. Guess this is issue with IS or known thing which i might not know.
Please suggest me is there any function available in installscript which can wait until my exe finishes its work other than LaunchAppandWait. I tried with Shell32.ShellExecuteA and it works fine but it wont wait until my exe is finished its work. Or can i make some how ShellExecuteA to wait in installscript to wait some how?
Need help in this
Sarfu
LaunchAppandWait
sarfu
, May 13 2008 12:58
Posted 15 May 2008 - 05:10
I am having no clue why i am not able to launch application with launchapp in patchuiafter.
Is there any doc available or is this issue with installscript.
Can some body suggest me how to launch and wait for the applcation result with installscript ?
sarfu
sarfu
Posted 26 May 2008 - 10:31
Sarfu,
Check this below mentioned function
LaunchAppAndWait ( szProgram, szCmdLine, nOptions );
in nOptions use LAAW_OPTION_WAIT....
regards
Narain
regards
Narain
Posted 02 June 2008 - 15:28
I did tried all the parameters.
guess its a bug with IS script. Now m launching from command line cmd and pass exe as parameter.
Thanks for the help
Thanks for the help
Posted 03 June 2008 - 18:20
Well, I can think of two solutions:
1) use the ShellExceuteEx + WaitForSingleObject in a custom DLL function.
2) I have not tried this but it might work, Use ShellExecute with Start APPNAME /wait
Regards,
Regards,
