So far nothing has worked. I've tried componentupdate and this will not install the object. I've created a new component, set it's selected property to true using componentselectitem, and it doesn't install the object. Componentreinstall doesn't work either if the object is added to a previously installed component.
Componentupdate actually doesn't seem to work at all during a repair. I've changed the componentreinstall to componentupdate in the maintuibefore and it only installs files, no extra components.
I need to build this so my install will not have to uninstall the component and reinstall it.
Does anyone know how to do this? Am I going to have to add the files individually to my build and then run repair? Or maybe create a completely new install so I can install one object? If so, this is really bad.
