UPDATE query throws error in selective MSI tables
eelisdotnet
, Jul 14 2005 12:22
Posted 14 July 2005 - 12:22
The following query returned error 2259: 'Table(s) Update failed'
Cscript WiRunSQL.vbs Setup.msi "UPDATE `ControlCondition` SET `ControlCondition`.`Action`='Hide' WHERE `ControlCondition`.`Dialog_`='FolderForm' AND `ControlCondition`.`Control_`='AllUsersRadioGroup'" |
I tried to run it in several formats (without grave marks or without the
'ControlCondition.' prefix for the column). The same error occured on the
Upgrade table during an attempt to run UPDATE query.
SELECT and DELETE queries on those tables were successfully executed.
Note also that the values were successfully updated by hardcoding in Orca.
Is there any limitations on some MSI tables ?
Posted 14 July 2005 - 13:40
Again quoting the SQL Syntax help topic:
| UPDATE queries only work on nonprimary key columns. |
In the ControlCondition table all four columns are key.
Posted 14 July 2005 - 14:51
Thanks again Stefan.
How can I run an UPDATE query for those tables/columns ?
Or, is it better to DELETE and INSERT a new record ...
Posted 15 July 2005 - 09:27
I tried to run this automation script with the View.Modify method.
Option Explicit Const msiOpenDatabaseModeReadOnly = 0 Const msiOpenDatabaseModeTransact = 1 ' Connect to Windows Installer object On Error Resume Next Dim installer : Set installer = Nothing Set installer = Wscript.CreateObject("WindowsInstaller.Installer") : CheckError ' Open database Dim databasePath : databasePath = Wscript.Arguments(0) Dim database, openMode, view, record, updateMode openMode = msiOpenDatabaseModeTransact Set database = installer.OpenDatabase(databasePath, openMode) : CheckError Set view = database.OpenView("SELECT `Action` FROM ControlCondition WHERE `Dialog_`='FolderForm' AND `Control_`='AllUsersRadioGroup' AND `Action`='Show'") : CheckError view.Execute : CheckError updateMode = msiViewModifyReplace Set record = view.Fetch : CheckError If Not record Is Nothing Then record.StringData(0) = "Hide" ' update record view.Modify updateMode, record : CheckError End If database.Commit : CheckError Wscript.Quit 0 Sub CheckError Dim message, errRec If Err = 0 Then Exit Sub message = Err.Source & " " & Hex(Err) & ": " & Err.Description If Not installer Is Nothing Then Set errRec = installer.LastErrorRecord If Not errRec Is Nothing Then message = message & vbNewLine & errRec.FormatText End If Fail message End Sub Sub Fail(message) Wscript.Echo message Wscript.Quit 2 End Sub |
I keep getting errors like: Microsoft VBScript runtime error 1F4: Variable is undefined.
With a quick debugging I think the error comes from this line:
'Set record = view.Fetch : CheckError'
Can't figure out any undeclared variables...
Posted 15 July 2005 - 14:37
The error probably comes from one line higher - I don't see msiViewModifyReplace being defined anywhere.
BTW Two hints for developing scripts:
1. Comment out any exception handling (On Error Resume Next), that way you'll allow the Windows Scripting Host to identify the line with the error.
2. If you have the Script Debugger installed (comes with Office, VStudio), run using this command:
WScript.exe //x "C:\my first script.vbs" "First param" "Second Param"
Note the //x: it starts your script debugger.
(You can also use CScript.exe, in that case the text of WScript.Echo is forwarded to the console).
Posted 18 July 2005 - 12:08
Thanks Zweitze,
somehow I missed the msiViewModifyReplace const declaration... it turned to be the undefined variable of course.
The script debugger is also great in monitoring the code execution. Thanks for the debugging tips as well.
cheers!
cheers!
