I've encountered the following issue:
I have a custom action which takes around 20 seconds to complete.
Is there a way to identify click on the "cancel" button in the middle of the custom action?
The problem is that if I click on cancel the rollback process doesn't happen.
I would appreciate your help.
Lilach
Cancel installation during custom action
lilache
, Nov 22 2010 17:26
Posted 26 November 2010 - 00:47
Assuming you have a DLL custom action:
Every second or so your code should call MsiProcessMessage() - for instance, to update the progress indicator, or to update the status text. That function returns -1 when cancel was pressed (the -1 is from memory, check first). In that case, the DLL custom action should return 2.
Actually MsiProcessMessage also asks the user for a confirmation. So, when you do get that result the user already confirmed the cancelling.
Finally, that -1 is returned only once. Make sure you handle it right the first time.
Posted 28 November 2010 - 08:05
Thanks for your reply.
In this case the custom action is not a DLL but an executable which is installed with the application.
Does your solution works only when the custom action is a DLL?
Posted 30 November 2010 - 16:43
I believe my solution also works for script custom actions - I know it has a function like MsiProcessMessage, although I am not sure whether it supports a similar return value. You'll have to check that.
But EXEs... they run in their own address space - seperated from the rest of Windows. You cannot control a running installation, communicate with some running installation or anything like that. A DLL is the way to go.
