Hello,
we are using Installshield 2010. We are using the standarddialog for choosing the installationdirectory. Is it possible to prevent the user from choosing a networkdrive as target for the INSTALLDIR?
Thanks for your help
Best Regards
Manfred
Prevent Networkdrive as installdir
mri0202
, Jan 13 2011 12:54
Posted 13 January 2011 - 15:51
Using dialog editor you can open the InstallChangeFolder dialog, select the DirectoryCombo control and select which types of drives it will display. Set Show Remote to False.
However I think this wouldn't prevent users from manually entering a network location. So you miay need to use a custom action to check whether INSTALLDIR points to a network location. BTW you will need this anyway because INSTALLDIR could even be set on the command line.
Posted 20 January 2011 - 14:36
Thanks Stefan,
your training course in Kassel is to long ago. I can't remember how to make and how to bind a 'custom action' in Installshield.
Any help is welcome.
Kind Regards
Manfred
Kind Regards
Manfred
Edited by mri0202, 20 January 2011 - 14:36.
Posted 20 January 2011 - 18:25
So long ago that even I don't call it...
You can use the custom action wizard, or start with help topic "Custom Actions"
