I created few custom dialogs from the standard visualstudiodialogs using ORCA. I was able to design dialogs with combination of controls.
My requirement is to test the database connection by clicking the test button on a dialog which contains the Server, UserID, Password and Port Edit fields.
Can we execute methods based on UI action on a dialog. If so how.
The UI looks as in the attached image.
Please help me in this.
Thank in advance.
Thank you,
Hemanth Kumar Gunnam
Misys Software Solutions
hemanthyours@gmail.com
UI CustomAction in CustomDialog designed in Orca
hemanthyours
, Mar 27 2008 07:51
Posted 01 April 2008 - 14:16
You can call a custom action from a dialog button using the DoAction event.
Posted 02 April 2008 - 16:52
| QUOTE (Stefan Krueger @ 2008-04-01 14:16) |
| You can call a custom action from a dialog button using the DoAction event. |
I added a control event DoAction with argument as a custom action name.
In the custom action table i added the type as 1 i.e for calling a binary.
I created an assembly using c#. I was trying to call the method in that assembly when i click on the test button. But when i click it its throwing an error that a dll is required.
Posted 05 April 2008 - 23:29
Type 1 is a DLL which exports a function, not an assembly.
Posted 15 April 2008 - 08:41
| QUOTE (Stefan Krueger @ 2008-04-05 23:29) |
| Type 1 is a DLL which exports a function, not an assembly. |
Thank you very much
