I tried to add one but only a part of it is being shown.
What is actual size of picture that I can add.
And Is there any way to add picture on the title bar.
Thanks.
Posted 07 February 2002 - 09:06
Thanks.
Posted 07 February 2002 - 17:30
For the details on this, see IS KB article Q105029.
IS doesn't mention the exact size, so you have to figure it out yourself (I submitted a feature request to IS about this).
To change the image in the titlebar, you use the DialogSetInfo() function. See the IS help for details on the image size.
Note that if you change the default SdWelcome() image and use a custom title bar image, you will have to create a "transparent" image to replace the default image that IS will put on it. I used a 5-pixel image with all bits set to black, and used it with "transparent" for black bits turned on.
