There is a requirement in my project according to which I have to add the support of a windows service in my setup.Interesting part is , my setup is a non admin setup and the service requires admin credentials. Is there any way to run this service on non admin machine using my setup(which is a non admin setup) or this is an impossible task.
I tried to look for the solution of this particular query on net but of no luck.
Alex
Windows service in non admin setup
AlexLX
, Jan 30 2012 15:35
Posted 30 January 2012 - 17:08
You may be able to install a service using a user account without admin rights. However, if your service needs admin rights, then a non-admin setup cannot grant it admin permissions. Noone can grant himself admin rights, this would be a security hole.
Posted 30 January 2012 - 17:18
Thanks for the quick reply Stefan. Yes my service requires admin credentials.
That is what I was telling my seniors of my project,but they want if there is a way.
Can you please let me know how do a user can create a service(which does not require admin credential) using my setup. Is this using Advanced Settings in Component ?
Alex
Alex
Posted 30 January 2012 - 17:32
I've never tried it, but you can specify the account in which the service should run (in advanced settings).
