I used following code to add progress text and ticks to progress bar, this code works to some extent. It adds progress text properly I see progress text when "for" loop gets executed to send progress text to MSI but same "for" loop does not work when it sends message to MSI to add progress ticks. It is adding progress text but progress animation is not happening here. Please have a look at following code and let me know if I need to make some changes to get it working.
'*************************** Common Custom Actions ****************************
Const INSTALLMESSAGE_ACTIONSTART = &H08000000
Const INSTALLMESSAGE_ACTIONDATA = &H09000000
Const INSTALLMESSAGE_PROGRESS = &H0A000000
' deferred action to increment ticks while action is taking place
Function AddProgressInfo( )
Set rec = Installer.CreateRecord(3)
rec.StringData(1) = "callAddProgressInfo"
rec.StringData(2) = "Incrementing the progress bar..."
rec.StringData(3) = "Incrementing tick [1] of [2]"
Message INSTALLMESSAGE_ACTIONSTART, rec
rec.IntegerData(1) = 1
rec.IntegerData(2) = 1
rec.IntegerData(3) = 0
Message INSTALLMESSAGE_PROGRESS, rec
Set progrec = Installer.CreateRecord(3)
progrec.IntegerData(1) = 2
progrec.IntegerData(2) = 5000
progrec.IntegerData(3) = 0
rec.IntegerData(2) = 5000000
For i = 0 To 5000000 Step 5000
rec.IntegerData(1) = i
' action data appears only if a text control subscribes to it
Message INSTALLMESSAGE_ACTIONDATA, rec
Message INSTALLMESSAGE_PROGRESS, progrec
Next ' i
' return success to MSI
AddProgressInfo = 0
End Function
' immediate action that adds a number of "ticks" to the progress bar
Function AddTotalTicks( )
rec.IntegerData(1) = 3
rec.IntegerData(2) = 5000000 ' total ticks to add
Set rec = Nothing
AddTotalTicks = 0
End Function
How to add ticks to progress bar
Amol_MSI
, Oct 06 2008 08:21
