Good evening Mr the gurus,
I have a DLL that contains a CA. This DLL will need to call another DLL, which is supplied by a third-party and that I can't modify.
I have tried simply adding the second DLL to the BinaryTable but of course it didn't work; MSI outputs binaries with temporary encoded names (idb?).
What should I do?
Thanks.
Chained DLL
mrouthier
, Mar 19 2002 04:05
Posted 19 March 2002 - 09:56
You need to use the msi database commands to read the second dll out of the binary table into a temporary location. You can then call it.
In outline
hDatabase = MsiGetActiveDatabase(hInstaller)
MsiDatabaseOpenView(hDatabase,
"SELECT * FROM Binary WHERE Name='BinaryName'"
&hView);
MsiViewExecute(hView, 0);
MsiViewFetch(hView, &hRecord);
Count = MsiRecordDataSize(hRecord,2);
// This is ok for smalll files otherwise we will need to
// iterate.
pBuffer = malloc(Count);
MsiRecordReadString(hRecord,
2,
pBuffer,
&Count);
Now you can write pBuffer out to a file. Do not forget to close all the handles and add error checking.
Hope this helps
In outline
&hView);
// iterate.
2,
pBuffer,
&Count);
Hope this helps
Posted 21 March 2002 - 10:11
Glad to help.
In case anybody else reads the above. MsiRecordReadString should be MsiRecordReadStream.
Sorry for any inconvenience that may of caused.
