I have a general question about the InstallShield but not sure whether this is the right track to post the question.
I have a need to create an installation (Basic MSI or InstallScript MSI) that incorporates a set of silent installations (again, could be Basic MSI or InstallScript MSI). I am trying to embed some third party software installers along with my product feature in a single installation. Each of the third party installers will be installed in silent mode. The third party installers, of course, could be Basic MSI or InstallScript MSI. What would be the proper approach to package such a nested installation?
I'd appreciate any suggestions or advice. Thanks.
Regards,
Shuh
An installation for a set of silent installations
shuh.chang
, Apr 30 2006 09:33
Posted 01 May 2006 - 04:00
If you want to run third party installers from your installer, then using a basic MSI, you would have to use a couple of nested msi custom actions. Im not sure if you can do this with Install Script.
Your best bet would be to obtain the merge modules for these setup, then you could compile the merge modules into your setup.
