Upgrade Property
PHYOE2004
, Jun 05 2012 04:24
Posted 05 June 2012 - 04:24
Hi All,
The InstallScript MSI Project can be used Upgrades features if I have some InstallScript on my project?
Regards,
Phyoe
Regards,
Phyoe
Posted 05 June 2012 - 09:29
I'm not sure I understand your question.
In general, the "InstallScript MSI" project type should be avoided, in my opinion.
If you have a "Basic MSI" project with some InstallScript custom actions, you can also use "Basic MSI" to upgrade it.
Posted 05 June 2012 - 10:02
Dear Stefan,
Initially, I am using Basic MSI Project (.msi) . On that time my installer don't ask any popup message - To allow user to choose Install Drive (C or D)
1- Server Name ( To define at the config file)
2- Let user to choose specific application to install (Setup Type)
3- Checking Excel.exe path
4- Checking previous version's application is still running or not.
5- Writing some configuration to the config file during installation.
We only do
A- upgrade (completely uninstall previous version and install new one)
B- Custom Action (New Exe) to register
So we decided to move to InstallScript MSI Project. Then we allow 1 to 5 plus A and B features. So I write most of the features at the InstallScript. Except Item A the rest are working well. I try to find this problem at the forum but cannot get any answer.
Please Help.
BTW. My IS version is InstallShield Developer 8
Thanks & Regards,
Phyoe
Here is My Install Script Code.
We only do
Please Help.
Thanks & Regards,
Phyoe
//////////////////////////////////////////////////////////////////////////////// // // File Name: Setup.rul // // Description: InstallShield script // // Comments: This script was generated based on the selections you made in // the Project Wizard. Refer to the help topic entitled "Modify // the script that the Project Wizard generates" for information // on possible next steps. // ///////////////////////////////////////////////////////////////////////////////// // Include header files #include "ifx.h" #define HWND_BROADCAST 0xffff #define WM_WININICHANGE 0x001A #define VERSIONID ////////////////////// global defines //////////////////////////// string svHostname,svHomeairport; number nXpSp2installed, nAcceptPorts; string EXCELDIR, XSYSDIR, XTMPDIR, XAPPDIR, XCEDA; string svLocal; //number nFidasInstalled, nFipsInstalled,nCheck1,nCheck2,nCheck3,nCheck4,nCheck5,nCheck6; //////////////////// installation declarations /////////////////// // //////////////////// user function declarations /////////////////// prototype CheckXPSp2(); prototype GetExcelPath(); prototype SetEnvironment(); prototype DelEnvironment(); prototype WriteToCedaIni(); prototype WriteToTelexPoolIni(); prototype CheckDotNet2(); prototype CheckDotNet4(); //////////////////// installation declarations /////////////////// // ----- DLL function prototypes ----- // your DLL function prototypes // ---- script function prototypes ----- // your script function prototypes // your global variables ////////////////////////////////////////////////////////////////////////////// // // FUNCTION: OnFirstUIBefore // // EVENT: FirstUIBefore event is sent when installation is run for the first // time on given machine. In the handler installation usually displays // UI allowing end user to specify installation parameters. After this // function returns, ComponentTransferData is called to perform file // transfer. // /////////////////////////////////////////////////////////////////////////////// function OnFirstUIBefore() LIST listStartCopy,listComponents; string Installdrive,svDrive,svDisk,svTimeSetting; string szName,svRes1,svRes2,szEnv,szComponents; string szTargetdir,szTitle,szMsg,szPath,szKey; string szLicenseFile, szQuestion,szHost,szHopo,szSetupType; POINTER pEnv; number bvCheck1,bvCheck2,custResult,nCustCheck1; number nCustCheck2, nVar,k, nResult,number_foo; number number_Result(24),nvResult,nvUTC, nvLocal; begin // TO DO: if you want to enable background, window title, and caption bar title //Initialize Variables //szSetupType = ""; //Set Setup-Type custom or SdProductName ("®"); // Set ProductName for %P //New installation if !MAINTENANCE then szHost="YourServerName"; szHopo="XXX"; listComponents = ListCreate(STRINGLIST); endif; //IF MAINTENANCE // Check for WINDOWS XP Service Pack 2 CheckXPSp2(); // Check for .NET Framework 2.0 nResult = CheckDotNet2(); if nResult < 0 then nResult = AskYesNo(".NET Framework 2.0 not found. Do you want to install .NET Framework 2.0?",YES); if nResult = YES then if (LaunchAppAndWait(SUPPORTDIR^"dotnetfx20.exe"," /q:a /c:\"install /qb\"", WAIT) < 0) then MessageBox ("Unable to install the .NET 2.0 Framework.\nPlease contact your System-Administrator",SEVERE); endif; else MessageBox ("Please make sure, that the .NET Framework 2.0 is installed.", SEVERE); abort; endif; endif; //Check for .NET Framework 4.0 nResult = CheckDotNet4(); if nResult < 0 then nResult = AskYesNo(".NET Framework 4.0 Client Profile not found. Do you want to install .NET Framework 4.0 Client Profile?",YES); if nResult = YES then if (LaunchAppAndWait(SUPPORTDIR^"dotNetFx40_Client_x86_x64.exe"," /q:a /c:\"install /qb\"", WAIT) < 0) then MessageBox ("Unable to install the .NET 4.0 Framework Client Profile.\nPlease contact your System-Administrator",SEVERE); endif; else MessageBox ("Please make sure, that the .NET Framework Client Profile 4.0 is installed.", SEVERE); abort; endif; endif; //Read Excel Path from Registry GetExcelPath(); // Beginning of dialogs label Dlg_SdWelcome: szTitle = VERSIONID; szMsg = "The Install Shield® Wizard will install ® \n" + "on your workstation. To continue click Next"; nResult = SdWelcome( szTitle, szMsg ); //Ask for Firewall configuration if Windows XP + Sp 2 is installed and the firewall is actve if nXpSp2installed = 1 then nResult = AskYesNo("The -Setup has detected that the WINDOWS Firewall is installed on your workstation. \n"+ "To run the ®-Client Applications properly if the WINDOWS Firewall is active,\n®-Setup has to open ports through the WINDOWS Firewall.\n"+ "Do you allow ®-Setup open ports for the ®-Client Applications?",YES); if nResult = NO then nResult = AskYesNo("Do you wish to install ®-Client Applications on your workstation\nand configure the WINDOWS Firewall manually? \n"+ "If you do NOT aggree, ®-Setup will terminate immediately!",YES); if nResult = YES then nAcceptPorts = 0; else abort; endif; else nAcceptPorts = 1; endif; endif; //License dialog Dlg_SdLicense: Enable (BACKBUTTON); szLicenseFile = SUPPORTDIR ^ "license.txt"; szTitle = ""; szMsg = ""; szQuestion = ""; nResult = SdLicense( szTitle, szMsg, szQuestion, szLicenseFile ); if nResult = BACK goto Dlg_SdWelcome; svDrive = "C"; //igu on 22/03/2012 //Define variables for the X Environment INSTALLDIR = svDrive + ":\\"; //Set Installation Directory XSYSDIR = INSTALLDIR + "\X\\System"; XTMPDIR = INSTALLDIR + "\Tmp"; XAPPDIR = INSTALLDIR + "\X\\Appl"; XCEDA = INSTALLDIR + "\X\\System\\Ceda.Ini"; // Choose Complete or Custom Installation Dlg_SetupType: szTitle = ""; szMsg = ""; nResult = SetupType2 ( szTitle , szMsg ,"", COMPLETE , 0 ); //if nResult = BACK goto Dlg_AskDrive; if nResult = BACK goto Dlg_SdLicense; if nResult = CUSTOM then // CUSTOM -Dialog Dlg_SdComponentTree: szTitle = ""; szMsg = ""; szTargetdir = INSTALLDIR; szComponents = ""; nResult = SdFeatureDialog2(szTitle, szMsg, szTargetdir, szComponents); if nResult = BACK goto Dlg_SetupType; number_foo = 0; number_Result(0) = FeatureIsItemSelected(MEDIA,"Bdps_Sec"); number_Result(1) = FeatureIsItemSelected(MEDIA,"Bdps_Uif"); number_Result(2) = FeatureIsItemSelected(MEDIA,"Bdps_Pass"); number_Result(3) = FeatureIsItemSelected(MEDIA,"Fips"); number_Result(4) = FeatureIsItemSelected(MEDIA,"RulesEditorFips"); number_Result(5) = FeatureIsItemSelected(MEDIA,"TelexPool"); number_Result(6) = FeatureIsItemSelected(MEDIA,"GroupEditor"); number_Result(7) = FeatureIsItemSelected(MEDIA,"StatusManager"); number_Result(8) = FeatureIsItemSelected(MEDIA,"FlightPermits"); number_Result(9) = FeatureIsItemSelected(MEDIA,"LogTabViewer"); number_Result(10) = FeatureIsItemSelected(MEDIA,"RulesChecker"); number_Result(11) = FeatureIsItemSelected(MEDIA,"AIMSViewer"); number_Result(12) = FeatureIsItemSelected(MEDIA,"ExportTool"); number_Result(13) = FeatureIsItemSelected(MEDIA,"ImportTool"); for k = 0 to 13 if number_Result(k) = 1 then number_foo = 1; endif; endfor; if number_foo = 0 then MessageBox ("Please select at least one option!",INFORMATION); goto Dlg_SdComponentTree; endif; szSetupType = "CUSTOM"; else //Complete selection szSetupType = "COMPLETE"; endif; //Dialog for input the Hostname Dlg_AskHost: SetDialogTitle ( DLG_ASK_TEXT, "Enter the Hostname" ); nResult = AskText ( "Please insert the name(s) of the host(s) you will be connected to. \n"+ "Please make sure that you can connect to the host(s) by using the given name(s). \n"+ "If you are unsure what to insert here, leave the default or contact your administrator." ,szHost, svRes1); svHostname = svRes1; if nResult = BACK goto Dlg_SetupType; //Dialog for input the Homeairport Dlg_AskHopo: SetDialogTitle ( DLG_ASK_TEXT, "Enter the Homeairport" ); nResult = AskText ( "Please insert the value for your home-airport. \n"+ "The value has to be 3 characters long and is usually the 3-letter code of your airport.\n"+ "If you are unsure what to insert here, leave the default or contact your administrator." ,szHopo, svRes2); svHomeairport = svRes2; if (nResult = BACK) goto Dlg_AskHost; //Dialog for choosing UTC/Local Dlg_AskTimeSetting: nvUTC = TRUE; nvLocal = FALSE; SetDialogTitle ( DLG_ASK_OPTIONS, "Select Time Setting" ); nResult = AskOptions ( EXCLUSIVE,"Please select the default time setting:", "UTC", nvUTC, "Local", nvLocal); if (nvUTC = TRUE) then svLocal = "FALSE"; svTimeSetting = "UTC"; else svTimeSetting = "Local"; svLocal = "TRUE"; endif; if (nResult = BACK) goto Dlg_AskHopo; //Show Installation-parameter Enable(BACKBUTTON); szTitle = "Check Setup Information"; szMsg = "Setup has enough information to begin the file-transfer operation.\n" + "If you want to review or change any of the settings, click Back.\n" + "If you are satisfied with the settings, click Next to begin copying files."; listStartCopy = ListCreate( STRINGLIST ); szName = "X® client application setup ... ready to install!"; ListAddString(listStartCopy,"Setup Type: " + szSetupType,AFTER); ListAddString(listStartCopy,"Host Name: " + svHostname,AFTER); ListAddString(listStartCopy,"Homeairport: " + svHomeairport,AFTER); ListAddString(listStartCopy,"Time Setting: " + svTimeSetting,AFTER); ListAddString(listStartCopy,"Install Dir: " + INSTALLDIR + "X",AFTER); ListAddString(listStartCopy," ",AFTER); ListAddString(listStartCopy,szName,AFTER); nResult = SdStartCopy( szTitle, szMsg, listStartCopy ); ListDestroy(listStartCopy); if (nResult = BACK) goto Dlg_AskTimeSetting; // setup default status SetStatusWindow(0, ""); Enable(STATUSEX); StatusUpdate(ON, 100); return 0; end; /////////////////////////////////////////////////////////////////////////////// // // FUNCTION: OnEnd // // EVENT: End event is the last event. It is not sent if the installation // has been aborted. In this case Abort event is sent // /////////////////////////////////////////////////////////////////////////////// function OnEnd() LIST list_comp; string list(50),svDir,szProgram,szCmdLine,svresult; string ListApp(50),szRunOnce,szKey; number i,j,nResult; begin if !MAINTENANCE then // setting ceda.ini entries nResult = WriteToCedaIni(); if nResult < 0 then MessageBox ("Setting X®-Configuration failed(CEDA INI)! Please contact your System-Administrator",SEVERE); endif; // setting Telexpool.ini entries nResult = WriteToTelexPoolIni(); if nResult < 0 then MessageBox ("Setting X®-Configuration failed(TELEX POOL CONFIG)! Please contact your System-Administrator",SEVERE); endif; //Check for Tmp-folder and create if not exist if ExistsDir (XTMPDIR) =! 0 then CreateDir (XTMPDIR); endif; // Registering components SdShowMsg ("Registering necessary X®-Components . . .",TRUE); // all this is inside winnt\system32 dir // leave the atl.dll as first component to be registered list(0) = WINSYSDIR + "\\atl.dll"; list(1) = WINSYSDIR + "\\MSWINSCK.ocx"; list(2) = WINSYSDIR + "\\MSCOMCTL.ocx"; list(3) = WINSYSDIR + "\\Mscomct2.ocx"; list(4) = WINSYSDIR + "\\Mscal.ocx"; list(5) = WINSYSDIR + "\\MSCHRT20.ocx"; list(6) = WINSYSDIR + "\\Msstdfmt.dll"; list(7) = WINSYSDIR + "\\SYSINFO.ocx"; list(8) = WINSYSDIR + "\\COMDLG32.ocx"; list(9) = WINSYSDIR + "\\Comctl32.ocx"; list(10) = WINSYSDIR + "\\Tabctl32.ocx"; list(11) = WINSYSDIR + "\\Ogocxgrd.ocx"; list(12) = WINSYSDIR + "\\ardespro2.dll"; list(13) = WINSYSDIR + "\\arpro2.dll"; list(14) = WINSYSDIR + "\\Arview2.ocx"; list(15) = WINSYSDIR + "\\PropList.ocx"; list(16) = WINSYSDIR + "\\exclexpt.dll"; list(17) = WINSYSDIR + "\\htmlexpt.dll"; list(18) = WINSYSDIR + "\\pdfexpt.dll"; list(19) = WINSYSDIR + "\\rtfexpt.dll"; list(20) = WINSYSDIR + "\\textexpt.dll"; list(21) = XSYSDIR + "\\XCom.ocx"; list(22) = XSYSDIR + "\\TAB.ocx"; list(23) = XSYSDIR + "\\AATLogin.ocx"; list(24) = XSYSDIR + "\\UGantt.ocx"; list(25) = XSYSDIR + "\\UCom.ocx"; szProgram = "regsvr32.exe"; RegDBSetDefaultRoot(HKEY_LOCAL_MACHINE); //register all ActiveX-components for i = 0 to 25 szCmdLine = "/s " + "\"" + list(i) + "\""; nResult = LaunchAppAndWait (szProgram, szCmdLine, WAIT); if nResult < 0 then szRunOnce = szProgram + " /s " + list(i); nResult = RegDBSetKeyValueEx(szKey, list(i), REGDB_STRING, szRunOnce, -1); endif; endfor; nResult = LaunchAppAndWait (XSYSDIR + "\\BcProxy.exe", "/REGSERVER",WAIT); if nResult < 0 then MessageBox ("BcProxy.exe not unregistered! \n",WARNING); endif; nResult = LaunchAppAndWait (XSYSDIR + "\\XAppMng.exe", "/REGSERVER",WAIT); if nResult < 0 then MessageBox ("XAppMng.exe not unregistered! \n",WARNING); endif; SdShowMsg ("",FALSE); //Hide Message-Window //Set X-Ports in WINDOWS Firewall-Configuration if (nXpSp2installed = 1 && nAcceptPorts = 1) then SdShowMsg("Configure X®-Ports...",TRUE); Delay(2); Disable(LOGGING); szKey = "SYSTEM\\CurrentControlSet\\Services\\SharedAccess\\Parameters\\FirewallPolicy\\StandardProfile\\GloballyOpenPorts\\List"; nResult = RegDBSetKeyValueEx(szKey, "3350:TCP", REGDB_STRING, "3350:TCP:*:Enabled:X", -1); szKey = "SYSTEM\\CurrentControlSet\\Services\\SharedAccess\\Parameters\\FirewallPolicy\\StandardProfile\\GloballyOpenPorts\\List"; nResult = RegDBSetKeyValueEx(szKey, "3351:UDP", REGDB_STRING, "3351:UDP:*:Enabled:X_BC", -1); szKey = "SYSTEM\\CurrentControlSet\\Services\\SharedAccess\\Parameters\\FirewallPolicy\\StandardProfile\\GloballyOpenPorts\\List"; nResult = RegDBSetKeyValueEx(szKey, "3352:UDP", REGDB_STRING, "3352:UDP:*:Enabled:X_BC2", -1); szKey = "SYSTEM\\CurrentControlSet\\Services\\SharedAccess\\Parameters\\FirewallPolicy\\StandardProfile\\GloballyOpenPorts\\List"; nResult = RegDBSetKeyValueEx(szKey, "3357:TCP", REGDB_STRING, "3357:TCP:*:Enabled:X_BCR", -1); szKey = "SYSTEM\\CurrentControlSet\\Services\\SharedAccess\\Parameters\\FirewallPolicy\\StandardProfile\\GloballyOpenPorts\\List"; nResult = RegDBSetKeyValueEx(szKey, "3358:TCP", REGDB_STRING, "3358:TCP:*:Enabled:X_BCQ", -1); Enable(LOGGING); SdShowMsg ("",FALSE); endif; //Set Environment variables nResult = SetEnvironment(); if nResult < 0 then MessageBox ("Setting X®-Environment failed! Please contact your System-Administrator",SEVERE); abort; endif; //Reboot system if wanted if (SdFinishReboot ("Thank you for choosing X® for your airport-operation.", "Setup has completed installing X®-Client Applications.", SYS_BOOTMACHINE, "Click Finish to exit X® setup.", 0) < 0) then MessageBox ("Reboot failed. Please call your administrator.", SEVERE); endif; /* MessageBox("Thank you for choosing X® for your airport-operation.\n\n"+ "Setup has finished installing X® client applications on your workstation and will terminate now.\n\n"+ "Do not forget to restart your computer before using X®-client applications.\n\n\n"+ "© X Airport Solutions GmbH",INFORMATION); */ endif; // if maintenance end; /////////////////////////////////////////////////////////////////////////////// // // FUNCTION: OnMaintUIBefore // // EVENT: MaintUIBefore event is sent when end user runs installation that // has already been installed on the machine. Usually this happens // through Add/Remove Programs applet. In the handler installation // usually displays UI allowing end user to modify existing installation // or uninstall application. After this function returns, // ComponentTransferData is called to perform file transfer. // /////////////////////////////////////////////////////////////////////////////// function OnMaintUIBefore() NUMBER nResult,nReturn,nType,nvType,nvSize,i; STRING list(50),svDir,svResult,svValue; STRING szTitle,szPath,szMsg,szKey,szProgram,szCmdLine; begin // TO DO: if you want to enable background, window title, and caption bar title // SetTitle( @TITLE_MAIN, 24, WHITE ); // SetTitle( @TITLE_CAPTIONBAR, 0, BACKGROUNDCAPTION ); // SetColor(BACKGROUND,RGB (0, 128, 128)); //Enable( FULLWINDOWMODE ); //SetFont(FONT_TITLE,STYLE_SHADOW,"Arial"); //SetTitle( VERSIONID, 16, WHITE ); //Enable( BACKGROUND ); //Read the X Path from Environment if (GetEnvVar ("XSYSTEM",XSYSDIR)) < 0 then XSYSDIR = "C:\\X\\System"; //not found? Set to default endif; //Any X-Application still running? if (Is (FILE_LOCKED, (XSYSDIR + "\\bcserv32.exe"))) = TRUE then MessageBox("One or more X® client applications are already running. Close these applications before uninstalling X®", WARNING); abort; endif; if (Is (FILE_LOCKED, (XSYSDIR + "\\BCComServer.exe"))) = TRUE then MessageBox("One or more X® client applications are already running. Close these applications before uninstalling X®", WARNING); abort; endif; if (Is (FILE_LOCKED, (XSYSDIR + "\\BcProxy.exe"))) = TRUE then MessageBox("One or more X® client applications are already running. Close these applications before uninstalling X®", WARNING); abort; endif; ///////////////////////////// // Remove all X-Components SetDialogTitle(DLG_ASK_TEXT, "Remove X®-Components from Workstation"); nResult = AskYesNo("This will remove all X® components and the complete X® directory " + INSTALLDIR + "\X\ from your Workstation!\n"+ "Please make sure to have saved all files you need from those directories or from related subdirectories!\n"+ "Do you wish to proceed ? (If you do NOT aggree setup will terminate immediately!)",NO); //Unregister X-Components if nResult = YES then list(0) = XSYSDIR + "\\AATLogin.ocx"; list(1) = XSYSDIR + "\\TAB.ocx"; list(2) = XSYSDIR + "\\XCom.ocx"; list(3) = XSYSDIR + "\\UGantt.ocx"; list(4) = XSYSDIR + "\\UCom.ocx"; list(5) = WINSYSDIR + "\\ardespro2.dll"; list(6) = WINSYSDIR + "\\arpro2.dll"; list(7) = WINSYSDIR + "\\Arview2.ocx"; list(8) = WINSYSDIR + "\\PropList.ocx"; list(9) = WINSYSDIR + "\\exclexpt.dll"; list(10) = WINSYSDIR + "\\htmlexpt.dll"; list(11) = WINSYSDIR + "\\pdfexpt.dll"; list(12) = WINSYSDIR + "\\rtfexpt.dll"; list(13) = WINSYSDIR + "\\textexpt.dll"; SdShowMsg ("Unregistering X®-Components . . .",TRUE); //nResult = LaunchAppAndWait (XSYSDIR + "\\BcProxy.exe", "/UNREGSERVER",WAIT); //if nResult < 0 then // MessageBox ("BcProxy.exe not unregistered! \n",WARNING); //else // MessageBox ("BcProxy.exe unregistered successfully! \n",INFORMATION); //endif; //nResult = LaunchAppAndWait (XSYSDIR + "\\XAppMng.exe", "/UNREGSERVER",WAIT); //if nResult < 0 then // MessageBox ("XAppMng.exe not unregistered! \n",WARNING); //else // MessageBox ("XAppMng.exe unregistered successfully! \n",INFORMATION); //endif; szProgram = "regsvr32.exe"; // remove all X-components for i = 0 to 13 szCmdLine = "-s -u " + "\"" + list(i) + "\""; nResult = LaunchAppAndWait (szProgram, szCmdLine, WAIT); if nResult < 0 then MessageBox (list(i) + "\nComponent not unregistered ! \n",WARNING); // else // MessageBox (list(i) + "\nComponent unregistered successfully! \n",INFORMATION); endif; endfor; SdShowMsg ("",FALSE); //Delete X-Ports from Registry when set szKey = "SYSTEM\\CurrentControlSet\\Services\\SharedAccess\\Parameters\\FirewallPolicy\\StandardProfile\\GloballyOpenPorts\\List"; RegDBSetDefaultRoot(HKEY_LOCAL_MACHINE); Disable(LOGGING); nReturn = RegDBGetKeyValueEx(szKey, "3350:TCP", nvType, svValue, nvSize); if (nReturn = 0) then SdShowMsg("Remove X®-Ports...",TRUE); Delay(2); RegDBDeleteValue(szKey, "3350:TCP"); endif; nReturn = RegDBGetKeyValueEx(szKey, "3351:UDP", nvType, svValue, nvSize); if (nReturn = 0) then RegDBDeleteValue(szKey, "3351:UDP"); endif; nReturn = RegDBGetKeyValueEx(szKey, "3352:UDP", nvType, svValue, nvSize); if (nReturn = 0) then RegDBDeleteValue(szKey, "3352:UDP"); endif; nReturn = RegDBGetKeyValueEx(szKey, "3357:TCP", nvType, svValue, nvSize); if (nReturn = 0) then RegDBDeleteValue(szKey, "3357:TCP"); endif; nReturn = RegDBGetKeyValueEx(szKey, "3358:TCP", nvType, svValue, nvSize); if (nReturn = 0) then RegDBDeleteValue(szKey, "3358:TCP"); SdShowMsg ("",FALSE); endif; Enable(LOGGING); //Delete X Environment variables nResult = DelEnvironment(); if nResult < 0 then MessageBox ("Deleting X®-Environment failed! Please contact your System-Administrator",SEVERE); endif; /* // Save CEDA.INI nResult = AskYesNo("Would you like to save your CEDA.INI? ",YES); if nResult = YES then Disable (LOGGING); // Protokollierung ausschalten nResult = CopyFile ("c:\\X\\system\\ceda.ini", "c:\\tmp\\Cedaini.bak"); if nResult < 0 then MessageBox ("Ceda.Ini could not be copied! \n",WARNING); else MessageBox ("Ceda.ini copied successfully as Cedaini.bak at C:\\Tmp \n",INFORMATION); endif; endif; Enable (LOGGING); // Protokollierung einschalten */ //Remove all features FeatureRemoveAll(); //Delete X-Folder with all subfolder szPath = INSTALLDIR + "\\X"; nResult = ExistsDir (szPath); if nResult = 0 then if (DeleteDir(szPath,ALLCONTENTS) < 0) then MessageBox ("X®-Application setup could not remove all directories/files !\nPlease make sure to (re)move those directories/files before next X®-Application setup!",INFORMATION); endif; endif; else SdShowMsg ("Terminating X®-Setup...",TRUE); Delay(2); SdShowMsg ("",FALSE); abort; endif; // setup default status SetStatusWindow(0, ""); Enable(STATUSEX); StatusUpdate(ON, 100); end; ////////////////////////////////////////////////////////////////////////////// // // FUNCTION: OnFileLocked // // EVENT: FileLocked event is sent during file transfer when a file that needs // to be overwritten or removed is in use by other application. // This event will not be sent for files that are in file group // marked as potentially locked. In this case operation is automatically // performed after reboot. // // ARGUMENTS: File - full path of file that is locked // // RETURN: ERR_IGNORE - engine should ignore the file and continue file transfer // ERR_RETRY - engine should retry to perform operation on the file // ERR_ABORT - file transfer should be aborted // ERR_PERFORM_AFTER_REBOOT - necessary operation should be performed // after system is rebooted // /////////////////////////////////////////////////////////////////////////////// function OnFileLocked(File) begin return ERR_PERFORM_AFTER_REBOOT;//SdExceptions(LOCKED, File); end; ////////////////////////////////////////////////////////////////////////////// // FUNCTION: OnError // // EVENT: The Error event is triggered from the External UI handler // when MSI sends an INSTALLMESSAGE_ERROR message. ///////////////////////////////////////////////////////////////////////////// function OnError(szMessage, nButtons_Icons) string szTitle; begin szTitle = SdLoadString(STR_STR_DEFERRORTITLE); //"Error" szTitle = @PRODUCT_NAME + " " + szTitle; return SprintfBox(nButtons_Icons|MB_ICONHAND, szTitle, szMessage); end; ////////////////////////////////////////////////////////////////////////////// // // FUNCTION: OnBegin // // EVENT: Begin event is always sent as the first event during installation. // ////////////////////////////////////////////////////////////////////////////// function OnBegin() begin // TO DO: you may change default non-UI setting, for example // // You may also perform your custom initialization steps, check requirements, etc. //Set X-Logo DialogSetInfo(DLG_INFO_ALTIMAGE, SUPPORTDIR ^ "Xlogo.bmp", TRUE); //Check Administrator-Rights if (Is (USER_ADMINISTRATOR, "") != TRUE) then MessageBox("You must have local administrator " + "privileges to run this setup. \n Please login as local administrator or call your administrator \n to install this software!", SEVERE); abort; endif; end; ////////////////////////////////////////////////////////////////////////////// // // FUNCTION: CheckXPSp2 // // EVENT: Function checks for existing WINDOWS XP Service Pack 2 Installation // with active WINDOWS Firewall // ////////////////////////////////////////////////////////////////////////////// function CheckXPSp2() string szKey, szNumName, svNumValue, szMsg; number nResult, nvType, nvSize; begin RegDBSetDefaultRoot(HKEY_LOCAL_MACHINE); szKey = "SYSTEM\\CurrentControlSet\\Services\\SharedAccess\\Parameters\\FirewallPolicy\\StandardProfile"; szNumName = "EnableFirewall"; nResult = RegDBGetKeyValueEx (szKey, szNumName, nvType, svNumValue, nvSize); if nResult < 0 then nXpSp2installed = 0; else nXpSp2installed = 1; endif; end; ////////////////////////////////////////////////////////////////////////////// // // FUNCTION: CheckDotNet4 // // EVENT: Function checks for existing .NET Framework 2.0 Installation // // ////////////////////////////////////////////////////////////////////////////// function CheckDotNet4() string szKey; number nResult; begin // Registry Key for .NET 4.0 RegDBSetDefaultRoot(HKEY_LOCAL_MACHINE); szKey = "SOFTWARE\\Microsoft\\.NETFramework\\Policy\\v4.0"; nResult = RegDBKeyExist ( szKey ); if nResult < 0 then return (-1); else return(0); endif; end; ////////////////////////////////////////////////////////////////////////////// // // FUNCTION: WriteToCedaIni // // EVENT: Function writes etries to the Ceda.Ini // // ////////////////////////////////////////////////////////////////////////////// function WriteToCedaIni() STRING ListApp(50), szFileName, szSectionName, szKeyName1,szKeyName2,szKeyName3, szReplaceValue1,szReplaceValue2,szReplaceValue3; number j, nResult, nvType, nvSize; begin //Check for Ceda.Ini if (Is (FILE_EXISTS, (XSYSDIR + "\\Ceda.Ini")) = FALSE) then return -1; endif; //SprintfBox(INFORMATION," Excel Suche","Excel gefunden in Pfad: %s",svNumValue); //Write HOSTNAME, HOMEAIRPORT and HOSTTYPE inti the Ceda.Ini sections // setting ceda.ini entries ListApp(0) = "GLOBAL"; ListApp(1) = "BDPS-SEC"; ListApp(2) = "BDPSPASS"; ListApp(3) = "BDPS-UIF"; ListApp(4) = "FIPS"; ListApp(5) = "Rules"; ListApp(6) = "EXPORT"; ListApp(7) = "BcProxy"; ListApp(8) = "XAPPMAN"; ListApp(9) = "LOGTABVIEWER"; ListApp(10) = "HUBMANAGER"; ListApp(11) = "GRP"; szFileName = XCEDA; szKeyName1 = "HOSTNAME"; szKeyName2 = "HOMEAIRPORT"; szKeyName3 = "HOSTTYPE"; szReplaceValue1 = svHostname; szReplaceValue2 = svHomeairport; szReplaceValue3 = "Solaris 9"; SdShowMsg("Setting X®-Config parameter ...",TRUE); Delay(2); for j = 0 to 11 szSectionName = ListApp(j); WriteProfString (szFileName, szSectionName, szKeyName1, szReplaceValue1); WriteProfString (szFileName, szSectionName, szKeyName2, szReplaceValue2); WriteProfString (szFileName, szSectionName, szKeyName3, szReplaceValue3); endfor; //Write parameter to the sections WriteProfString (szFileName, "GLOBAL", "HelpDirectory", INSTALLDIR + "X\\Help"); WriteProfString (szFileName, "GLOBAL", " ##XVersion", VERSIONID); WriteProfString (szFileName, "BDPS-SEC", "INIFILE", INSTALLDIR + "X\\System\\BDPS_SEC.CFG"); WriteProfString (szFileName, "BDPS-UIF", "GROUPING", INSTALLDIR + "X\\Appl\\GRP.EXE"); WriteProfString (szFileName, "BDPS-UIF", "EXCEL", EXCELDIR); WriteProfString (szFileName, "FIPS", "BDPS-UIF", INSTALLDIR + "X\\Appl\\BDPSUIF.EXE"); WriteProfString (szFileName, "FIPS", "TELEXPOOL", INSTALLDIR + "X\\Appl\\TELEXPOOL.EXE"); WriteProfString (szFileName, "FIPS", "PASSINFO", INSTALLDIR + "X\\Appl\\BDPSPASS"); WriteProfString (szFileName, "FIPS", "RULES", INSTALLDIR + "X\\Appl\\RULES.EXE"); WriteProfString (szFileName, "FIPS", "IMPORTFLIGHTS", INSTALLDIR + "X\\Appl\\IMPORTFLIGHTS.EXE"); WriteProfString (szFileName, "FIPS", "BDPS-UIF", INSTALLDIR + "X\\Appl\\BDPSUIF.EXE"); WriteProfString (szFileName, "FIPS", "LOATABVIEWER", INSTALLDIR + "X\\Appl\\LOADTABVIEWER.EXE"); WriteProfString (szFileName, "FIPS", "LOGTABVIEWER", INSTALLDIR + "X\\Appl\\LOGTAB_VIEWER.EXE"); WriteProfString (szFileName, "FIPS", "FLIGHTPERMITS", INSTALLDIR + "X\\Appl\\FLIGHTPERMITS.EXE"); WriteProfString (szFileName, "FIPS", "CHECK_LIST_PROCESSING", INSTALLDIR + "X\\Appl\\CheckListProcessing.exe"); WriteProfString (szFileName, "FIPS", "EXCEL", EXCELDIR); WriteProfString (szFileName, "FIPS", "DEBUG", INSTALLDIR + "Tmp\\Fips.Log"); WriteProfString (szFileName, "FIPS", "LOGO", INSTALLDIR + "X\\System\\Airportlogo.bmp"); WriteProfString (szFileName, "XAPPMAN", "TLX_LAUNCH_STR", INSTALLDIR + "X\\Appl\\TELEXPOOL.EXE /CONNECTED"); WriteProfString (szFileName, "EXPORT", "TextPath", INSTALLDIR + "X\\System"); WriteProfString (szFileName, "STATUSMANAGER", "CHECK_LIST_PROCESSING", INSTALLDIR + "X\\Appl\\CheckListProcessing.exe"); WriteProfString (szFileName, "STATUSMANAGER", "PRINTLOGO", INSTALLDIR + "X\\System\\Airportlogo.bmp"); WriteProfString (szFileName, "GATPOS", "BlockedBitmap1", INSTALLDIR + "X\\System\\notvalid1.bmp"); WriteProfString (szFileName, "GATPOS", "BlockedBitmap2", INSTALLDIR + "X\\System\\notvalid2.bmp"); WriteProfString (szFileName, "GATPOS", "BlockedBitmap3", INSTALLDIR + "X\\System\\notvalid3.bmp"); WriteProfString (szFileName, "GATPOS", "BlockedBitmap4", INSTALLDIR + "X\\System\\notvalid4.bmp"); WriteProfString (szFileName, "GATPOS", "BlockedBitmap5", INSTALLDIR + "X\\System\\notvalid5.bmp"); WriteProfString (szFileName, "GATPOS", "BlockedBitmap6", INSTALLDIR + "X\\System\\notvalid6.bmp"); WriteProfString (szFileName, "FlightPermits", "PRINTLOGO", INSTALLDIR + "X\\System\\Airportlogo.bmp"); WriteProfString (szFileName, "HUBMANAGER", "PRINTLOGO", INSTALLDIR + "X\\System\\Airportlogo.bmp"); //Set the time setting WriteProfString (szFileName, "FIPS", "SEASONLOCAL", svLocal); WriteProfString (szFileName, "FIPS", "DAILYLOCAL", svLocal); WriteProfString (szFileName, "FIPS", "GATPOSLOCAL", svLocal); SdShowMsg ("",FALSE); end; ////////////////////////////////////////////////////////////////////////////// // // FUNCTION: WriteToTelexPoolIni // // EVENT: Function writes path entries to the TelexPool.Ini // // ////////////////////////////////////////////////////////////////////////////// function WriteToTelexPoolIni() STRING szFileName; number nResult, nvType, nvSize; begin //Check for Telexpool.Ini if (Is (FILE_EXISTS, (XSYSDIR + "\\Telexpool.Ini")) = FALSE) then return -1; endif; szFileName = XSYSDIR + "\\Telexpool.Ini"; //Write path-entries WriteProfString (szFileName, "MAIN_WINDOW", "LOADTAB_VIEWER", INSTALLDIR + "X\\Appl\\LoadTabViewer.exe"); //WriteProfString (szFileName, "MAIN_WINDOW", "IMPORT_TOOL", INSTALLDIR + "X\\Appl\\Importflights.exe"); end; ////////////////////////////////////////////////////////////////////////////// // // FUNCTION: SetEnvironment // // EVENT: Function sets the X Environment-Variables in the Registry // // ////////////////////////////////////////////////////////////////////////////// function SetEnvironment() string szKey,lsv_GetPathVarialble; number nResult; begin SdShowMsg("Setting X®-Environment...",TRUE); Delay(2); Disable(LOGGING); szKey = "SYSTEM\\CurrentControlSet\\Control\\Session Manager\\Environment"; RegDBSetDefaultRoot(HKEY_LOCAL_MACHINE); nResult = RegDBSetKeyValueEx(szKey, "XSYSTEM", REGDB_STRING, XSYSDIR, -1); if (nResult < 0) then return -1; endif; nResult = RegDBSetKeyValueEx(szKey, "XAPPL", REGDB_STRING, XAPPDIR, -1); if (nResult < 0) then return -1; endif; nResult = RegDBSetKeyValueEx(szKey, "XTMP", REGDB_STRING, XTMPDIR, -1); if (nResult < 0) then return -1; endif; nResult = RegDBSetKeyValueEx(szKey, "CEDA", REGDB_STRING, XCEDA, -1); if (nResult < 0) then return -1; endif; //Read path-variable from registry nResult = GetEnvVar ("Path",lsv_GetPathVarialble); if (nResult < 0) then return -1; endif; //SprintfBox (INFORMATION, "Test", "XSYSDIR: %s ",XSYSDIR); if (!(lsv_GetPathVarialble % XSYSDIR)) then //Append X-Systempath to path-variable lsv_GetPathVarialble = XSYSDIR + ";" + lsv_GetPathVarialble; //Write new path-variable to registry nResult = RegDBSetKeyValueEx(szKey, "Path", REGDB_STRING, lsv_GetPathVarialble, -1); if (nResult < 0) then return -1; endif; //else // MessageBox ("X-Path schon vorhanden", SEVERE); endif; Enable(LOGGING); SdShowMsg ("",FALSE); end; ////////////////////////////////////////////////////////////////////////////// // // FUNCTION: DelEnvironment // // EVENT: Function deletes the X Environment-Variables from the Registry // // ////////////////////////////////////////////////////////////////////////////// function DelEnvironment() string szKey,svValue; number nResult,nvType,nvSize; begin SdShowMsg("Delete X®-Environment...",TRUE); Delay(2); Disable(LOGGING); szKey = "SYSTEM\\CurrentControlSet\\Control\\Session Manager\\Environment"; RegDBSetDefaultRoot(HKEY_LOCAL_MACHINE); nResult = RegDBGetKeyValueEx(szKey, "XSYSTEM", nvType, svValue, nvSize); if (nResult = 0) then RegDBDeleteValue(szKey, "XSYSTEM"); endif; nResult = RegDBGetKeyValueEx(szKey, "XAPPL", nvType, svValue, nvSize); if (nResult = 0) then RegDBDeleteValue(szKey, "XAPPL"); endif; nResult = RegDBGetKeyValueEx(szKey, "XTMP", nvType, svValue, nvSize); if (nResult = 0) then RegDBDeleteValue(szKey, "XTMP"); endif; nResult = RegDBGetKeyValueEx(szKey, "CEDA", nvType, svValue, nvSize); if (nResult = 0) then RegDBDeleteValue(szKey, "CEDA"); endif; Enable(LOGGING); SdShowMsg ("",FALSE); end; ////////////////////////////////////////////////////////////////////////////// // // FUNCTION: Check Excel-Path // // EVENT: Function checks for existing the Excel-Path in the Registry // // ////////////////////////////////////////////////////////////////////////////// function GetExcelPath() string szKey, szNumName, svNumValue, szMsg, szFileName; number nResult, nvType, nvSize; begin szFileName = "Excel.exe"; RegDBSetDefaultRoot(HKEY_LOCAL_MACHINE); szKey = "SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\App Paths\\Excel.exe"; szNumName = "Path"; nResult = RegDBGetKeyValueEx (szKey, szNumName, nvType, svNumValue, nvSize); if nResult < 0 then MessageBox ("Excel not found!!", SEVERE); else //SprintfBox(INFORMATION," Excel Suche","Excel gefunden in Pfad: %s",svNumValue); EXCELDIR = svNumValue + "Excel.exe"; endif; end; ////////////////////////////////////////////////////////////////////////////// // // FUNCTION: CheckDotNet2 // // EVENT: Function checks for existing .NET Framework 2.0 Installation // // ////////////////////////////////////////////////////////////////////////////// function CheckDotNet2() string szKey; number nResult; begin // Registry Key for .NET 2.0 RegDBSetDefaultRoot(HKEY_LOCAL_MACHINE); szKey = "SOFTWARE\\Microsoft\\.NETFramework\\Policy\\v2.0"; nResult = RegDBKeyExist ( szKey ); if nResult < 0 then return (-1); else return(0); endif; end; |
Posted 06 June 2012 - 16:59
I think you have to add a "Major Upgrade" item in the releases view (or something like that, I don't exactly recall Developer 8).
Posted 07 June 2012 - 02:43
Dear Stefan,
Thanks for your reply. Yes I do Major Upgrade and I always change Product Code upon new Installer generation. What I do I suspect is, during Un-installation he removed all the files then he goes to OnEnd() Event. OnEnd() Event has writing some config on the application's configuration file and some other registration (you can check on my script) and raise error. Then he continue to process the installation.
at OnEnd() Event I already put if !MAINTENANCE then condition why he still process? How can I avoid for it?
Thanks for your support.
Thanks & Regards,
Phyoe
Thanks & Regards,
Phyoe
Posted 07 June 2012 - 08:10
I'm not sure. Did you verify the value of MAINTENANCE in the debugger? I don't know what script events are called in which order during a major upgrade of an InstallScript MSI project. Variables like MAINTENANCE might even be shared between the two installations.
