OK, here is the scenario. We have an install that calls installed .exe's via Custom Actions. The main .exe called basically makes a backup copy of an Access database, compacts it then updates it with information.
The problem is that some users don't have enough disk space available for the completion of this operation. What I would like to do is search for the database during the initial stages of the install, get size info and multiply that by three. Then, I would like to add this to the total cost of the installation.
What would be the best way to go about doing this? I don't know where/in what property the actual cost of the installation is held when calculated.
Does anyone have any starting points?
Accounting for additional install costs ...
Superfreak3
, Mar 13 2003 16:07
Posted 14 March 2003 - 11:15
I would write to the ReserveCost table at runtime. Means: Search for the file, calculate the cost and then use a SQL statement to write to the ReserveCost table at setup runtime.
Barbara
Barbara
The difference between theory and practice is larger in practice than in the theory.
