We have been using AdminStudio 2.0, 3.0, and 3.01 for the past year. We deploy our software remotely with windows 2000 active directory. With AdminStudio 3.5 we've noticed something different. If a user installs the software using the add/remove programs, add new programs - it will not let them uninstall it. After the program is installed the change button is greyed out and when the users try uninstalling they recieve and error saying they need to be local administrators to perform this function. This behavior wasn't present within the previous version of AdminStudio. Furthermore, if we make the user a local administrator is still shows the same error. Has anyone else experienced this and does anyone know what I need to do in my project to keep it from happening?
AdminStudio 3.5 question
kemptrandy8
, Nov 13 2002 21:43
Posted 16 January 2003 - 17:55
Have you checked the Add/Remove Program Settings for the package. If this all looks fine then either go to the Direct Editor and check the property table or open the package in Orca. If you sort by the first column then the settings you are looking for are ARPNOREMOVE and ARPNOMODIFY. These settings should allow the user to install and uninstall if they are NOT present in the table.
