MSDE 2000
Josh Luth
, Oct 05 2001 15:44
Posted 05 October 2001 - 15:44
Now I know there have been numerous posts on here in the past regarding the MSDE 2000 merge mods. But I have yet to get it working 100%. I was hoping someone could provide information on exactly what needs to be done to get these to install without error, including which MSMs should be included. I know this is a big question, but if you can answer it for me, I know I won't be the only one who appreciates it.....
Posted 17 October 2001 - 00:37
I need to know these things too. I have it getting installed no problem; however, MSDE is getting installed to the default directories, and not the ones I'm specifying. Also, the InstanceName isn't being applied. ARGGHHH
Posted 29 October 2001 - 17:58
Josh Luth,
To get rib of the "configure error", you have to use three more merge modules. The following are merge modules you need to add to you project;
1. CONNECT.MSM
2. DEV_SCM.MSM
3. UPGRADE.MSM
Try it! It worked fro me...........Good luck!
1. CONNECT.MSM
2. DEV_SCM.MSM
3. UPGRADE.MSM
