Hi to all,
I wish enable/disable CDRom autorun feature inside my setup's script.
And I wish to do that without force the user to reboot the machine.
Microsoft Knowledge Base say:
How to Enable or Disable Automatically Running CD-ROMs
(This article was previously published under Q155217)
There is no option to enable or disable automatically running CD-ROMs in the user interface. To enable or disable automatically running CD-ROMs, you must edit the registry:
1.
Click Start, click Run, type regedit in the Open box, and then press ENTER.
2.
Locate and click the following registry key:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\CDRom
3.
To disable automatically running CD-ROMs, change the Autorun value to 0 (zero). To enable automatically running CD-ROMs, change the Autorun value to 1.
4.
Restart your computer.
Is there a no-reboot way to do that?
Maybe turning to some API function or other?
Thanks.
Ciao, Giuseppe
How to enable/disable autorun without reboot?
gronchi
, Feb 13 2003 09:19
Posted 13 February 2003 - 14:44
Did you try to manipulate the value with installscript and test, if the behaviour is different?
Do you want to insert a second cd? If yes, why do you add autorun.inf to it?
Do you want to restart while the cd is still in the drive? If yes, why do you look for a way without reboot? ...
Please tell more about the way you want to act and the os to react.
btw: another way to manipulate the autorun settings is to use a different key:
translated from german winfaq:
hth
| Quote |
HKEY_CURRENT_USER\ Software\ Microsoft\ Windows\ CurrentVersion\ Policies\ Explorer or HKEY_LOCAL_MACHINE\ Software\ Microsoft\ Windows\ CurrentVersion\ Policies\ Explorer value "NoDriveTypeAutoRun", data type REG_DWORD manipulate the first Byte to set autorun for devices the devices are coded bitwise bit value function 0 1 (1) all unknown devices deactivated 1 1 (2) unknown 2 1 (4) fdd and other changeable devices deactivated 3 1 (8) hdd deactivated 4 1 (16) network drives deactivated 5 1 (32) cdrom deactivated 6 1 (64) ram disk deactivated 7 1 (128) reserved default is hex 95 (dec 149: 1+4+16+128 = 149). examples 95 Autorun.inf is run automatically with cdrom B5 Autorun.inf is run on cdrom and hdd 00 autorun.inf is run on all drives (even fdd) FF Autorun.inf is run on no devices FD autostart is deactivated |
hth
Gruß / regards
Thomas
Thomas
Posted 13 February 2003 - 16:19
I know it can be done without a reboot because I've seen other software packages do it on-the-fly.
Posted 13 February 2003 - 16:49
You'll find some information here:
http://msdn.microsof...rary....tro.asp
The optimal solution would be to handle the message that Windows broadcasts before it starts to autoplay the CD. Unfortunately that's not possible inside your script. I believe you would have to launch an exe for this purpose.
The alternative - if you create the CD - would be to use a autorun program that wuld simply do nothing and exit immediately if your setup is running. (You can find such a program here on InstallSite in section Realted Tools -> CD Autorun)
Posted 18 February 2003 - 08:45
I built a IS project (just script work, no groups, components or other) install itself onto a machine. Then when I run it it drives the user to copy all CDRom setup he had into a web setup' repository (allow him to perform, in the future, a sort of web installation/update). Don't ask me why I choose InstallShield to do that...
So when user insert our old CDRom setup (with autorun) I need it don't start because that isn't the install-time but it's only the time to copy the CDRom setup under a web server. I also wish the user didn't reboot his machine!
I hope it's quite clear despite my poor english, anyway if you want other information I'm here.
Following is the answer Damien Carbery give me on official InstallShield forum:
http://community.ins...wthr....=111043
What do you think?
Next days I'll study his precious suggestion
Ciao,
Giuseppe
What do you think?
Ciao,
Giuseppe
