During installation I am changing default value of [INSTALLDIR] property:
(VBScript)
Session.Property("INSTALLDIR") = SOME_VALUE
But components that located in the "[INSTALLDIR]\subfolder" don't change it's destination to "[SOME_VALUE]\subfolder".
How can I resolve this problem ?
Trouble with change INSTALLDIR during installation
SerDev
, Jun 28 2004 16:39
Posted 29 June 2004 - 02:13
What are the componetn destinations?
The components might not have a parent of INSTALLDIR. You will need to look inside the directory table.
Posted 29 June 2004 - 09:07
All components have destinations such as:
"[INSTALLDIR]\folder1\folder2"
"[INSTALLDIR]\folder3"
All of them are in one Feature. Feature destination is also [INSTALLDIR].
CustomAction that change [INSTALLDIR] property runs after CostFinalize action.
Posted 29 June 2004 - 12:47
It looks like you are sequencing the action correctly. But maybe try to move it directly ahead of InstallInitialize. There is a good chance that this property is never set correctly in your VBScript. I would use a message box at the end of the script to verify that the value is actually set. Then I would add a new VBScript custom action directly after InstallFinalize to view the value of INSTALLDIR and make sure it is what you expect.
Posted 29 June 2004 - 13:10
Certainly I checked INSTALLDIR property before installation finish.
As I sad components that have destination only [INSTALLDIR] - moved correctly, and components that have destination [INSTALLDIR]\folder or [INSTALLDIR]\folder1\...\ not.
Posted 29 June 2004 - 23:31
hmm interesting
What is installed on the machine?? is it possible that the component was left behind from a previous uninstall?? so now the new install find the old component, and uses its old path?
Have you tried running the install with verbose logging? This reveal some more information
