can InstallShield Professional 7 do this ?
Can IS 7 do this ?
Lee Koh Ching
, Jul 03 2003 09:09
Posted 03 July 2003 - 09:09
I want to add a dialog box that will request user key-in a the active code , beside that my installation will verify the active code isn't right, if the active code not right, the installation will terminated. else the installation will continue run.
Posted 04 July 2003 - 11:18
Hello,
I'm not sure if i understand right, but you want to have a dialog and let the user enter a key. ok, lets use the is7 sdregisteruserex dialog like this:
Dlg_SdCustomerInformation:
szMsg = "";
szTitle = "";
nResult = SdRegisterUserEx( szTitle, szMsg, szName, szCompany, szSerial );
StrToUpper ( svUpper , szSerial );
szSerial = svUpper;
if (nResult = BACK) then
goto Dlg_SdLicense;
endif;
So you have the dialog and gets the szSerial back from the dialog
you can declare a funtion e.g. CheckUserID and call ist with
CheckUserID(szSerial);
inside the function you can check if the key is correct
if it is correct just return without doing anything and the setup will continue.
if the key is incorrect you can display a message box with
MessageBox("incorrect - setup will exit!", SEVERE);
and then exit the setup with
exit;
I hope it is the answer to your problem.
Greetings
C. Schaper
imos AG
Herford, Germany
szMsg = "";
szTitle = "";
szSerial = svUpper;
goto Dlg_SdLicense;
endif;
exit;
Greetings
C. Schaper
imos AG
Herford, Germany
Posted 15 July 2003 - 02:30
Thank You Very Much for your Helping.
Do you know IS 7 can checking the register key in user computer ?
What I mean is my setup will check some register key in user computer, if the register key exist , then the setup continue, else setup will terminate.
Hope you can help me.
Thank
Thank
Posted 27 October 2003 - 07:31
yes..you can do it by calling the function RegDBKeyExist()... this will check if you have the same registry key or name in the system registry exist.
