I’m coming with a question, can be called an Custom Action during Patch uninstallation?
I conditioned the CA with “MsiPatchRemovalList”. The CustomAction is not present in the main installer; it was added only in patch. This is the first patch, which is going to be applied.
I have already forgot, I’m using IS 11 and Basic MSI project. The patch is created from Patch Design.
Thank you for the support.
Later Edit:
I know that in order to run custom actions during patch uninstall, you must define a patch uninstall custom action in the original product installation package or in a patch that is not removable and will always be installed.
But how can I create two patches, of curse, the first not removable (which must not contain any modification, only to contain the CA), to install in the same time?
Actually, I want also , in add/remove to appear only the second patch, the one which can be uninstall.
The only way when it worked was when i have installed separatly the pathces, the first one which does nothing, contain only the CA. And then, the second one, which contains in addition some atoher modifications.
When I uninstalled the last patch applied, the CA was executed.
I think i have don't create corectly the patches ... the multipel pathces or I don't know.
Any help is welcomed.
Edited by sebica79, 30 November 2005 - 16:24.
