I am instantiating and destroying a COM object in the OnEnd() event handler.
The instantiation of the COM object is fine and also i am able to call the functions properly.
However as i try to destroy my COM object variable by setting it to NOTHING, i get the following error:
Member not found.
Is there any limitation as to destroying COM object references in the OnEnd event handler? Is this really required as the object variable is a local variable and will go ouot of scope as the function exits?
Any help would be very much appreciated.
Destroying a COM object variable throws an error.
kirann_hegde
, Dec 05 2009 07:42
