Hi
Anyone know how to perform a silent uninstall for an Installshield setup.exe? The
uninstallstring reads RunDll32 C:\PROGRA~1\COMMON~1\INSTAL~1\engine\6\INTEL3~1\ctor.dll,LaunchSetup "C:\Program Files\InstallShield Installation Information\{9FCF2FC0-8268-11D4-A313-0006290D766E}\setup.exe" ADD_REMOVE.
it keeps prompting to confirm uninstall. Is there a way I can do it silently so no prompts appears. I've trived creating a responsefile file but dosn't work.
The application is Checkpoint VPN-1 SecureClient NGX R60.
Many thanks
Uninstall silently ..setup.exe" ADD_REMOVE
IDRIS
, Jul 05 2006 11:51
Posted 05 July 2006 - 12:35
Use AutoIT or some similar tool to send the OK message for the uninstall dialog. Simple to use and you can run the created .exe after your uninstall custom action.
I had a similar problem once with a response file for a driver install.
http://www.autoitscript.com/autoit3/
