I placed a bitmap on the installation dialog boxes ( Some are custom defined and some are Standard ), I want to make back ground color of the bitmap to be transparent so that it coincides with the dialog box color. Can any one help on this?
Thanks in advance
Best Regards,
Venkat
How can I make bmp background to be transparent?
venki_1
, May 08 2002 08:02
Posted 13 May 2002 - 08:42
Hi venki_1,
Bitmaps can not be made transparent. Perhaps using icons is an option, since they can be made transparent (using a tool like MS visual studio. There may be some freeware tools on the net too.)
Posted 30 January 2003 - 10:21
In IS 5.x and 7.x there is a function called DialogSetInfo which is able to handle specific colors to be displayed transparent.
See the knowledge base for further information (Q100148 - HOWTO: Modifying Sd Dialogs Using DialogSetInfo ).
Maybe this is possible in IS6 too?
You just use
to set the color 0,128,128 (default background color, blueish green) to be transaprent, if the first parameter after the bitmap name is 1 ...
You just use
| Code Sample |
| DialogSetInfo(DLG_INFO_ALTIMAGE, SUPPORTDIR ^ "my.bmp;1;;;0,128,128", TRUE); |
Gruß / regards
Thomas
Thomas
