How can you tell exactly what is contained in a Merge Module? Does the Merge Module panel in the IDE tell the whole story?
I hope someone responds because I'm not sure if this new setup is working properly (message board). I usually get responses but haven't rec'd any from my last 3 posts.
Even if you can't answer my question, respond to let me know I'm function 'OK"!
Thanks, as always!
What's In a Merge Module
Superfreak3
, Mar 22 2002 17:48
Posted 22 March 2002 - 22:19
You can open the Merge Module in Orca and look at the tables. The file table will tell you which files are included for instance.
Posted 23 March 2002 - 01:51
By the way - You can also open merge modules directly into ISWI 2.x if you prefer ISWI to Orca (which I do) :-).
You just need to change the selection in the "Files of type" combo on the open dialog. ISWI actually "imports" the msm file and creates a new project. This is quite handy for fixing problems in merge modules from 3rd party sources.
